Label Expression Help
1386
09-22-2010 06:23 AM
BrettRosso
I was wondering if anyone could help me on a labeling VB expression that took duplicate values, say from an address field, and assigned a number of how many duplicate values there are to that point. The point in my case would be a water meter attached to a parcel that has many water meters with the same address, but needs a label saying how many there are in that parcel. I would appreciate any help.
Thanks so much,
Brett Rosso
*Here is the code that I have wrote so far, that i cannot get to work because im not a professional code writer.
Function FindLabel ( [ADDRESS] )
FindLabel = Counter ( [ADDRESS] )
End Function
Function Counter (address)
Dim PATTERN, Reg_exp
Set reg_exp = New RegExp
reg_exp.Execute = True
PATTERN = "\s{23,}"
'23 max characters in the Address field
reg_exp.pattern = PATTERN
result = PATTERN.items.count
Counter = result
End Function
*I am trying it through a spatial join at the moment, but will still accept help on creating an expression.
HeribertoMantilla_Santamaría
Hi.
The Address have separators? If is true, better use Split Function, the Split Function divide the text in array, and you can Count the total elements, i.e.
Dim cElement As Variant
Dim Element2 As String
Dim mCount As Long
Element2 = "1 2 3 4 5 6 "
cElement = Split(Element2, " ")
mCount = UBound(cElement) // 6 Numbers
If the last element no have the space, you can add it.
Now you can use too the Mid$ function in a while i.e.
Dim tTotal As Long
Dim iCount As Long
mCount = 1
Element2 = Element2 & Element2
iCount = 0
tTotal = Len(Element2)
While (mCount < tTotal)
    cElement = Mid$(Element2, mCount, 23)
    iCount = iCount + 1
    mCount = mCount + 23
Wend
MsgBox iCount
