IWorkspace.ExecuteSQL UPDATE with file geodatabase
1976
10-01-2012 10:53 AM
PatriceLabbé
Is it possible to use an UPDATE statement like the following one with file geodatabases (v9.3) :
UPDATE table_name SET field_name = another_field_name
This kind of code always throws an exception.
Thank you!
LanceShipman
Support has been extended at 10.1, but not at 9.3.
LanceShipman
UPDATE should work. It's certainly working at 10.1. What does your update statement look like?
PatriceLabbé
This works (set an arbitrary value):
string sql = "UPDATE hydro_so_100k SET HYD_NOM = 'nom', HYD_DESCR = 'description' WHERE FEU_NO like '%12%'"
These doesn't (update field value from another one's value):
string sql = "UPDATE hydro_so_100k SET HYD_NOM = HYD_NOM , HYD_DESCR = 'description' WHERE FEU_NO like '%12%'";
or
string sql = "UPDATE hydro_so_100k SET HYD_NOM = \"HYD_NOM\" , HYD_DESCR = \"HYD_DESCR\" WHERE FEU_NO like '%12%'";
I came across this link in my searches : http://forums.esri.com/Thread.asp?c=93&f=993&t=235859
At this point, file geodatabase does not support expressions in the SET clauses of an Update statement, we only support literal values. This is not a bug. We implemented what we needed, with the plan of expanding things over time.
It seems to confirm there were limitations with UPDATE statements. Is is still true with 9.3 version?
LanceShipman
