ITopologicalOperator.Buffer units
5075
03-02-2015 04:34 PM
TedRakel
The documentation for ITopologicalOperator.Buffer states that "The buffer distance is in the same units as the source shape that is being buffered".  The source shape in my case is a point feature.  How do I find out if I'm buffering that point by feet, meters, or inches?  The dataset that the point feature is in has a spatial reference as follows:
NAD_1983_StatePlane_Tennessee_FIPS_4100_Feet
WKID: 2274 Authority: EPSG
Projection: Lambert_Conformal_Conic
False_Easting: 1968500.0
False_Northing: 0.0
Central_Meridian: -86.0
Standard_Parallel_1: 35.25
Standard_Parallel_2: 36.41666666666666
Latitude_Of_Origin: 34.33333333333334
Linear Unit: Foot_US (0.3048006096012192)
Geographic Coordinate System: GCS_North_American_1983
Angular Unit: Degree (0.0174532925199433)
Prime Meridian: Greenwich (0.0)
Datum: D_North_American_1983
  Spheroid: GRS_1980
    Semimajor Axis: 6378137.0
    Semiminor Axis: 6356752.314140356
    Inverse Flattening: 298.257222101
XanderBakker
Esri Esteemed Contributor
The linearUnitName is Foot_US, so as the name suggests it is in feet.
XanderBakker
OwenEarley
If you need to figure out the units dynamically in ArcObjects you can do this using the IProjectedCoordinateSystem.CoordinateUnit property. This returns an ILinearUnit which has a Name property and MetersPerUnit property that is useful for any conversions you may need to apply to your buffer distance.
