I have the code to create a shapefile programmatically, something like this 28310 - Create a new empty shapefile programmatically
more over I am able to put the data from a layer in it.
It works perfectly.
Some client hands to me several layers that have data in Russian. When I export from my application to a shp file I got the same behavior described here esri - Character encoding support in geodatabases and shapefiles - Geographic Information Systems St... .
the fields with Cyrillic alphabet appears like ???????? .
I found this article: 21106 - Read and write shapefile and dBASE files encoded in various code pages but it does not apply to ArcEngine (arcObjects) .
Is there a way to change the codification when I'm creating the shp file using the workspace provided by the shapefileworkspacefactory?
