Is IWorkspace.ExecuteSQL synchronous or asynchronous?
3977
09-21-2015 05:31 PM
MarkMindlin
Desktop 10.3
I cannot find in documentation an answer for that.
And secondly, can I change that method to be synchronous/asynchronous?
Any documentation link or idea?
Was this method asynchronous in previous versions?
FreddieGibson
Honored Contributor
The method should be synchronous because it blocks the UI thread when you call it. Have you tried wrapping it within an asynchronous method? Examples of how to do this are available on the following pages:
Calling Synchronous Methods Asynchronously
https://msdn.microsoft.com/en-us/library/2e08f6yc(v=vs.110).aspx
Create an Asynchronous Method
http://www.csharp-examples.net/create-asynchronous-method/
MarkMindlin
Thanks Freddie,
Thank you for response.
Good suggestion.
Was this method asynchronous in previous versions? (before 10.3)
FreddieGibson
Honored Contributor
I don't believe this method was ever asynchronous.
MarkMindlin
Thank you Freddie,
Probably do you have an idea why execution of a procedure with this method blocks the table to which the procedure writes (meaning - I cannot read the table when procedure is executing)?
