Is it possible to start a model directly from an ArcMap-Toolbar?
5108
9
05-02-2012 07:08 PM
MOHAMMEDHABBOUB
Hello,
Is it possible to start a model (generated from model builder) directly from an ArcMap-Toolbar? I don't want to start the toolbox just for one frequently used tool.
I have 9.3 edition 🙂
thanks
DuncanHornby
MVP Notable Contributor
Mohammed,
Below is some VBA I used to execute a custom model in a toolbox, this should get you going.
Duncan
      ' Create workspacefactory     Dim pToolboxWorkspaceFactory As IWorkspaceFactory     Set pToolboxWorkspaceFactory = New esriGeoprocessing.ToolboxWorkspaceFactory          'Open a toolbox workspace     Dim pToolboxWorkspace As IToolboxWorkspace     Set pToolboxWorkspace = pToolboxWorkspaceFactory.OpenFromFile(g_ToolBoxPath, 0)          ' Connect to tool     Dim pGPToolBox As IGPToolbox     Set pGPToolBox = pToolboxWorkspace.OpenToolbox("WFD49e Processing Tools Enhanced.tbx")     Dim pGPTool As IGPTool     Set pGPTool = pGPToolBox.OpenTool("mdSubSetFloodplain")      ' Run tool     Dim pGPToolCommandHelper As IGPToolCommandHelper     Set pGPToolCommandHelper = New GPToolCommandHelper     pGPToolCommandHelper.SetTool pGPTool     pGPToolCommandHelper.Invoke Nothing      ' Destroy objects     Set pToolboxWorkspaceFactory = Nothing     Set pToolboxWorkspace = Nothing     Set pGPToolBox = Nothing     Set pGPTool = Nothing     Set pGPToolCommandHelper = Nothing
MOHAMMEDHABBOUB
anyone can help?
MOHAMMEDHABBOUB
I have wrote this code, but an error appears (see image):
Option Explicit
Private Sub UIButtonControl1_Click()
Public Sub Test()
  Dim pGP As Object
  Set pGP = CreateObject("esriGeoprocessing.GPDispatch.1")
On Error GoTo EH
pGP.AddToolbox ("D:\DRASTIC_MODEL.tbx")
  pGP.MyModel
  Exit Sub
EH:
  MsgBox pGP.GetMessages(), vbOKOnly, "Test"
End Sub
End Sub
reference: http://support.esri.com/en/knowledgebase/techarticles/detail/31110
Anyone can help?
DuncanHornby
Mohammed,
Duncan
MOHAMMEDHABBOUB
Hello Hornbydd,
first of all thanks for responding:
consedering that toolbox name:DRASTIC_MODEL, Model name: Model8
I worte the following :
Set pToolboxWorkspace = pToolboxWorkspaceFactory.OpenFromFile  (g_ToolBoxPath, 0)
' Connect to tool
Set pGPToolBox = pToolboxWorkspace.OpenToolbox("  DRASTIC_MODEL.tbx")
Set pGPTool = pGPToolBox.OpenTool("  Model8")
' Run tool
' Destroy objects
End Sub
Note: what does blue text mean (I a beginner in VBA)
Is there any any else modification? because error appears as illustrated in image
DuncanHornby
You need to replace my variable string g_ToolBoxPath with the folder where the tool box is. For example "C:\XYZ\ModelTools"
MOHAMMEDHABBOUB
This is what I got 😞
I saved the toolbox in D:\
Toolbox name: Drastic_Model.tbx
Model Name: Model5
see image
DuncanHornby
Are you using the correct name for the model?  For this line of code to be correct you need to be using the name not the label of your model.
Set pGPTool = pGPToolBox.OpenTool("xxx")
In toolbox right click on your model and go to properties. You should be using the model NAME not the LABEL.
Duncan
MOHAMMEDHABBOUB
Hello,
I don't know why is does not work. please see attached and check if there is some thing wrong
Thanks
MOHAMMEDHABBOUB
Hornbydd,
thanks a lot it works :). the problem is that i did not add the toolbox to arcmap toolboxes.:rolleyes:
Thanks again 🙂
