Is it possible to install Addin for all users on computer?
6166
08-06-2013 02:56 AM
BarbaraSchneider1
Hello,
when a user installs an Addin on a computer, it is only visible for this user. Is it possible to install it for all users on a computer?
Barbara
3 Solutions
JoeVondracek
Yes, if an admin on that computer creates a registry setting with a location to the add-in, then all users on that computer will automatically see that add-in.  Check out the help docs for "Advanced add-in concepts":
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/#/Advanced_add_in_concepts/0001000...
The relevant section is at the very bottom of that page.  "Administrators can also use the registry to specify additional folders to probe for add-ins. This feature can be used by administrators to control user access to add-ins. To add administrator folders, manually enter a new AddInFolders key under the Settings key and add a new string value for each add-in folder."
For example, if I create a registry string under HKLM\SOFTWARE\ESRI\Desktop10.1\Settings\AddInFolders called "D:\ArcGIS\AddIns", then any user running ArcMap on that computer will see any add-ins that have been placed in the D:\ArcGIS\AddIns folder as a Shared Add-In in ArcMap's Add-In Manager.  The users will NOT be able to delete those add-ins using the Add-In Manager.
Note: If you are running 64-bit Windows, the registry key will be under HKLM\SOFTWARE\Wow6432Node\ESRI\Desktop10.1\Settings\AddInFolders.  Also, you may have to create the AddInFolders key yourself under Settings.
FabianOrtega
Does anyone know if this solution also works for Pro last version (2.9.*) ?
I've followed all the steps but it doesn't work, so maybe I'm doing something wrong or something changed for Pro.
Fabian
FabianOrtega
Hi again,
Found the answer to my question in the documentation :
https://github.com/esri/arcgis-pro-sdk/wiki/ArcGIS-Pro-Registry-Keys
It works like a charm!
Sorry for the inconvenience.
Fabian
DuncanHornby
MVP Notable Contributor
If you place the AddIn in a folder that all users can reach (e.g. a sub-folder in the ArcGIS folder) then all users can log in under their own profile and navigate to it. If it is on a network drive then all users could navigate to it from any computer with ArcGIS...
JoeVondracek
BarbaraSchneider1
Hi Joe,
great, thanks!
Barbara
FabianOrtega
Fabian
FabianOrtega
Hi again,
Fabian
