Insufficient Permissions when using IFeatureClass.CreateFeature
1190
10-27-2011 07:03 AM
TravisSparks
I have connected successfully to an sde database using an IFeatureWorkspace, and have an IFeatureClass object for the feature class I want to work with.  When connected as a user that is NOT the owner of any feature classes, but that does have SELECT, INSERT, UPDATE, and DELETE permissions (using ISQLPrivilege) on the feature class, I am able to update existing features, but not create new ones.
To update, I use the IFeatureClass.GetFeature method to return an IFeature, I update the appropriate field values, and I call IFeature.Store, which updates the feature in the feature class successfully.  However, if I use IFeatureClass.CreateFeature to create a new feature to store in the feature class, I get an 'Insufficient Permissions' error.
I've tried wrapping the operations in an IWorkspaceEdit edit session and edit operation, but that doesn't have any effect in this case.  If I connect as the feature class owner, this all works fine, so it would seem that the approach is ok, minus this permission issue.
Any ideas?
NeilClemmons
Honored Contributor
What happens when you try creating a new feature in this feature class using ArcMap?  If you get a similar error then the problem is probably on the database side rather than in your code.
TravisSparks
It turns out I hadn't set the user privileges on the feature class inside ArcCatalog.  Is there some way to determine these feature class permissions via code?  I've been using the following, where PrimaryCPFeatureClass is a populated feature class:
IDataset dataset = (IDataset)PrimaryCPFeatureClass;
IDatasetName datasetName = (IDatasetName)dataset.FullName;
ISQLPrivilege sqlPriv = (ISQLPrivilege)datasetName;
The sqlPriv object was providing the privileges as they exist on the underlying SQL table, but apparently not the privileges of the sde feature class itself, which is what I need access to.
