In-memory workspace: how to check the existance of feature layer and tables?
1684
07-30-2012 08:26 AM
SuiHuang
Hi Everybody:
    I am developing an ArcMap 10 (service pack 4) customize tool. I want to use in-memory workspace to hold some temporary data, but found that the in-memory workspace I created does not support IWorkspace2 interface such that I cannot use IWorkspace2.NameExists to check whether table or feature class is already created. Following is the screenshot of the Watch window showing this fact:
[ATTACH=CONFIG]16477[/ATTACH]
   Is there any alternative to check the existance of objects in the in-memory workspace?
   Thank you!
KenBuja
MVP Esteemed Contributor
How about looping through the datasets in the workspace and seeing if the name ("YourFClass") is in there? I've tested this with an In-memory workspace.
Dim pEnumDS As ESRI.ArcGIS.Geodatabase.IEnumDataset Dim pDataset As ESRI.ArcGIS.Geodatabase.IDataset  pEnumDS = pWorkspace.Datasets(ESRI.ArcGIS.Geodatabase.esriDatasetType.esriDTAny)  Do Until pDataset Is Nothing     If pDataset.Name = "YourFClass" then         System.Windows.Forms.MessageBox.Show("Exists")         Exit Do     pDataset = pEnumDS.Next Loop
KenBuja
SuiHuang
Thank you Ken! Seems this is the only available way.
        Exit Do
Loop
