In ArcMap flash a point programmatically with the 'crosshairs' additional effect that the ESRI flash command does
3297
11-04-2015 01:58 PM
MarkMindlin
Hi there,
I see the old posts about that question, and the answer probably - no way (no 'crosshairs' programmatically).
But my little hope is that in version 10.3 it could exist.
Or some how I could use the
IFindCallBack.FlashGeometry() - Generic method to flash a point on the display n times.
See the link
ArcObjects Help for .NET developers
Any help will be appreciated.
FreddieGibson
Honored Contributor
I would assume that the logic shown on the following pages would need to be used to accomplish this. You'd have to select an appropriate symbol to make the symbol similar to the existing flash tool and you could probably draw lines that extend from the point to the edge of the display and use similar logic to flash them at the same times as the point.
Flash Geometry Snippet
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#//004900000075000000
Extending ArcObjects (IGeometry) - 08 - Flashing Geometry - YouTube
https://www.youtube.com/watch?v=h7TYtSK_04g&list=PLQnljOFTspQXqYsWJG8o-eJpGlvzww9lE&index=8
How to flash a point
http://forums.esri.com/Thread.asp?c=93&f=1147&t=284591
MarkMindlin
Thank you Freddie,
I see you point.
I already use it to flash a point (without flashing lines from the edge to the point). But the user asked about the "same" 100 % ESRI appearance.
So, I am searching API.
