Implement Icommand in VB.net
1658
07-01-2023 08:50 PM
Suman_Kar
I want to implement Icommand in VB.net. After build the dll file when I try to load this dll file in Arcmap 10.8 then it shows that can't load type library from specified file. I have used below code for implement this dll file. Please help on this
Imports ESRI.ArcGIS.SystemUI
Public Class Class1
Implements ESRI.ArcGIS.SystemUI.ICommand
Public Sub OnCreate(Hook As Object) Implements ICommand.OnCreate
m_pApp = Hook
Throw New NotImplementedException()
End Sub
Public Sub OnClick() Implements ICommand.OnClick
Dim MyForm As New Form1
MyForm.Show()
End Sub
Public ReadOnly Property Enabled As Boolean Implements ICommand.Enabled
Get
Enabled = True
End Get
End Property
Public ReadOnly Property Checked As Boolean Implements ICommand.Checked
Get
End Get
End Property
Public ReadOnly Property Name As String Implements ICommand.Name
Get
Name = "Merge Geodatabase V2.0"
End Get
End Property
Public ReadOnly Property Caption As String Implements ICommand.Caption
Get
Caption = "Merge Geodatabase V2.0"
End Get
End Property
Public ReadOnly Property Tooltip As String Implements ICommand.Tooltip
Get
Tooltip = "Merge Geodatabase V2.0"
End Get
End Property
Public ReadOnly Property Message As String Implements ICommand.Message
Get
End Get
End Property
Public ReadOnly Property HelpFile As String Implements ICommand.HelpFile
Get
HelpFile = ""
HelpFile = "Merge.hlp"
End Get
End Property
Public ReadOnly Property HelpContextID As Integer Implements ICommand.HelpContextID
Get
HelpContextID = 10001
End Get
End Property
Public ReadOnly Property Bitmap As Integer Implements ICommand.Bitmap
Get
End Get
End Property
Public ReadOnly Property Category As String Implements ICommand.Category
Get
Category = "Land_Suman"
End Get
End Property
End Class
BrentHoskisson
This looks like an older method of adding commands.  I recommend using Add-Ins.  ESRI has a walk-through Here .
Brent Hoskisson
DuncanHornby
MVP Notable Contributor
It's a long time since I've developed a DLL for ArcMap. AddIns are the much better way of developing and distributing customisation. That said I remember DLL's developed in .Net needed to be registered using RegASM.exe, have a look at the Q&A from 12 years ago...
