IGxObject.Category Values
3072
6
07-12-2010 09:37 PM
ThomasPolden
Does anyone know if there is a list of possible values for the IGxObject.Category property?
Cheers
ThomasPolden
I have done a bit of searching, but I can only find reference to ESRI probably having one not actually were to find it. Not having much luck with the ArcGIS program help either.
AndrewMay
You can have unlimited values as you can create your own impementation of the IGXObject interface - and specify whatever you want for the Catalog property.  So you can't really have a definitive list.  It does seem odd though that it's not easy to find a list of the standard ESRI ones.
The only help I can give is that if you run ArcGIS\bin\categories.exe and look under ESRI GX Object Factories then this gives you a list of all the implementations of IGXObject on your machine, although it doesn't give you the Catalog values.
What did you need a full list for?
KenBuja
MVP Esteemed Contributor
Take a look at this thread for alternate code to determine the type of an object from IGXObject. One problem I ran into when using IGxObject.Category is that the values are localized. For example, I wrote an application that worked perfectly fine on English language machines, but crashed in other languages. In my code, I was checking the type of table that was selected by a user. If I select a dbf file, this code will return a ShapefileWorkspaceFactoryClass.
        Select Case pGxObj.Category
          Case "Personal Geodatabase Table"
            pFact = New ESRI.ArcGIS.DataSourcesGDB.AccessWorkspaceFactoryClass
          Case "File Geodatabase Table"
            pFact = New ESRI.ArcGIS.DataSourcesGDB.FileGDBWorkspaceFactoryClass
          Case "dBASE Table"
            pFact = New ESRI.ArcGIS.DataSourcesFile.ShapefileWorkspaceFactoryClass
          Case "SDC Feature Class"
            pFact = New ESRI.ArcGIS.DataSourcesFile.SDCWorkspaceFactoryClass
          Case "SDE Table"
            pFact = New ESRI.ArcGIS.DataSourcesGDB.SdeWorkspaceFactory
          Case Else
            System.Windows.Forms.MessageBox.Show("Data type '" & pGxObj.Category & "' has not been coded yet...")
        End Select
However, when a user with a German language machine selected a dbf file, he reported getting the error message "Data type 'dBASE-Tabelle' has not been coded yet".
ThomasPolden
I have a application that searches through our filesystem and reports back on spatial data. I was using IGxObject.Category to catch the spatial data. But I noticed that it was not reporting back on some raster files. I eventually figured out I was only catching "File Geodatabase Raster Dataset" files when some of them were actually coming through IGxObject.Category as "fgdb Raster" or something similar. I just wanted a list of standard ESRI categories to make sure I was not missing anything else. But I have figured out a better way of catching everything now.
Still, it would be usefully to have such a list. One has to exist somewhere.
BrianO_Hare
Thomas,
What's the better way of catching the objects that you've found? I'm coding in C# so can't use GetType as it just returns System.__ComObject (other casts I've tried return null for some reason. I need to get a reference to the IWorkspace from the currently selected IGXObject.
cheers,
Brian O'Hare
NeilClemmons
Honored Contributor
Thomas,
cheers,
Brian O'Hare
Brian, try the following code.  You'll have to translate to C#.
If TypeOf gxObject Is IGxDataset Then
  Dim gxDataset As IGxDataset = DirectCast(gxObject, IGxDataset)
  Dim dataset As IDataset = gxDataset.Dataset
  Dim workspace As IWorkspace = dataset.Workspace
End If
