IEditSketch help
986
06-04-2013 12:32 PM
ChristopherGraf
I am trying to create a polygon and I am having trouble with the IEditSketch3 interface and Geometry IPoint Interface.
Some Relevant code:
pEditSketch = editor
point1 = pActiveview.ScreenDisplay.DisplayTransformation.ToMapPoint(arg.X, arg.Y)
            Try
                pEditSketch.AddPoint(point1, True)
            Catch ex As NullReferenceException
            End Try]
When I run this code I get an "Parameters are incorrect" error on the (pEditSketch.AddPoint(point1, True)) line . I don't see how that can be when I have a point and a Boolean value as parameters.
DuncanHornby
MVP Notable Contributor
Just thinking out aloud here, you are getting your point from the display, but this may be a different projection to the layer you are attempting to to digitize into?
