Dear everybody:
I have problems with this line of code:
pDS = pGPUtils.OpenFeatureClassFromString(ruta & outname)
The error message is in spanish:
"-2147467259 Devuelto error HRESULT E-Fail de una llamada a un componente COM"
You may see in the complete code that the code makes a selection of a combination of Featureclass-joined table. The sql-string gets one value of the for-next-structure and finally it checks if some records are selected. Only if their are some records selected it exports the selected records to a new shape.
This boocle is correct only for 1 selection. Once a shapfile is exported and the boocle repeats I get this error mentioned above in the following line of code:
What is wrong with the IDataset? Shall I initialize every time the boocle repeats? Their seems to be a COM problem but I don´t know what kind of?
Thanks very much for your help!!
Anika
Sub ExportSelectedFeatures_HabTodos_Bio()
' ---- Output Shapefile Name ----
Dim pGPUtils As IGPUtilities
Dim pDS As IDataset
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim pFeatSel As IFeatureSelection
Dim pGeoFtrLyr As IGeoFeatureLayer
Dim pFtrCls As IFeatureClass
Dim pExportOp As IExportOperation
Dim pInDsName As IDatasetName
Dim pOutFCName As IFeatureClassName
Dim pQryFltr As IQueryFilter
Dim pClone As IClone
Dim pGeomDef As IGeometryDef
Dim lShpFldIdx As Long
Dim pSelSet As ISelectionSet
Dim numlstbio As Integer
Dim k As Integer
Dim sql1 As String
pMxDoc = My.ArcMap.Document
pMap = pMxDoc.FocusMap
' Use GPUtilities to delete the shapefile if it exists
pGPUtils = New GPUtilities
On Error Resume Next
pFeatSel = pMap.Layer(numerolayer)
pGeoFtrLyr = pFeatSel
pFtrCls = pGeoFtrLyr.DisplayFeatureClass
numlstbio = Me.lstBio.Items.Count
' Create the Query
pQryFltr = New QueryFilter
For k = 0 To numlstbio - 1
nomlstbio = Me.lstBio.Items.Item(k)
Select Case numerolayer
Case Is = 0
outname = strCodUE & "_" & nombresigla & "_" & strDescCodHabit & "_" & nomlstbio & "_InvHab25.shp"
sql1 = "GIS_HAB25000_Etrs89_UTMBio.REGBIO = '" & nomlstbio & "' AND t" & nombresigla & ".CodHABITTODOS = '" & nombresigla & "'"
pQryFltr.WhereClause = sql1
Case Is = 1
outname = strCodUE & "_" & nombresigla & "_" & strDescCodHabit & "_" & nomlstbio & "_InvHabFlu.shp"
sql1 = "GIS_HabFlu_licsley_Etrs89_UTMBIO.REGBIO = '" & nomlstbio & "' AND t" & nombresigla & ".CodHABITTODOS = '" & nombresigla & "'"
Case Is = 2
outname = strCodUE & "_" & nombresigla & "_" & strDescCodHabit & "_" & nomlstbio & "_InvHabHum.shp"
sql1 = "GIS_HabHum_Etrs89_UTMBIO.REGBIO = '" & nomlstbio & "' AND t" & nombresigla & ".CodHABITTODOS = '" & nombresigla & "'"
End Select
pFeatSel.SelectFeatures(pQryFltr, esriSelectionResultEnum.esriSelectionResultNew, False)
pFeatSel.SelectionChanged()
pSelSet = pFeatSel.SelectionSet
If Err.Number = 0 Then pDS.Delete()
On Error GoTo 0
If pSelSet.Count > 0 Then
' Create the output Featureclass Name
pOutFCName = pGPUtils.CreateFeatureClassName(ruta & outname)
pDS = pFtrCls
' Get the Input Dataset Name
pInDsName = pDS.FullName
lShpFldIdx = pFtrCls.FindField(pFtrCls.ShapeFieldName)
pGeomDef = pFtrCls.Fields.Field(lShpFldIdx).GeometryDef
' Execute the export operation
pExportOp = New ExportOperation
pExportOp.ExportFeatureClass(pInDsName, pQryFltr, Nothing, pGeomDef, pOutFCName, 0)
pMxDoc.ActiveView.Refresh()
End If
End Sub
