IContentView3 Problem
3157
01-24-2012 09:46 AM
CarlTremblay
        I got a problem with IContentView3. I created a custom crontrol that implements IContentView3.
When I Add that ContentView with the AddContentsView method, I Got a system.NotImplementedException : Method or operation not implemented.
AddContentsView method takes has an IContentView parameter. Do I have to cast the IContentView3 control ?
Thank you verru much ...
  Dim ContentsView As ESRI.ArcGIS.ArcMapUI.IContentsView
  ContentsView = New ESRI.ArcGIS.ArcMapUI.TOCDisplayView
  Dim ContentsViewEdit As ESRI.ArcGIS.ArcMapUI.IContentsViewEdit
  ContentsViewEdit = DirectCast(VDQ.SDDI.EsriLib.ArcObjects.IU.ArcMap.EnvironnementArcMap.Instance.Application.Document,    ESRI.ArcGIS.ArcMapUI.IContentsViewEdit)
  ContentsView = New MyContentView    <---- IContentView3 Control
  ContentsViewEdit.AddContentsView(ContentsView)  <----------------------- System.NotImplementedException
Public Class MyContentView
    Implements ESRI.ArcGIS.ArcMapUI.IContentsView3
    Private Declare Ansi Function ShowWindow Lib "user32" (ByVal hwnd As Int32, ByVal nCmdShow As Int32) As Int32
    Private Const SW_HIDE As Integer = 0
    Private Const SW_SHOW As Integer = 9
#Region "Variables"
    Private m_UserControl As VDQ.SDDI.Localisation.IU.Windows.Localisation
#End Region
#Region "Conctructeur"
    Public Sub New()
        m_UserControl = New VDQ.SDDI.Localisation.IU.Windows.Localisation(VDQ.SDDI.EsriLib.ArcObjects.IU.ArcMap.ContexteApplication.Instance)
    End Sub
#End Region
    Public Sub Activate(parentHWnd As Integer, Document As ESRI.ArcGIS.ArcMapUI.IMxDocument) Implements IContentsView.Activate, IContentsView2.Activate, IContentsView3.Activate
        ShowWindow(m_UserControl.Handle.ToInt32, SW_SHOW)
    End Sub
    Public Sub AddToSelectedItems(item As Object) Implements IContentsView.AddToSelectedItems, IContentsView2.AddToSelectedItems, IContentsView3.AddToSelectedItems
    End Sub
    Public Sub BasicActivate(parentHWnd As Integer, Document As ESRI.ArcGIS.Framework.IDocument) Implements IContentsView2.BasicActivate, IContentsView3.BasicActivate
    End Sub
    Public Property ContextItem As Object Implements IContentsView.ContextItem, IContentsView2.ContextItem, IContentsView3.ContextItem
        Get
            Return Nothing
        End Get
        Set(value As Object)
        End Set
    End Property
    Public Sub Deactivate() Implements IContentsView.Deactivate, IContentsView2.Deactivate, IContentsView3.Deactivate
        ShowWindow(m_UserControl.Handle.ToInt32, SW_HIDE)
    End Sub
    Public ReadOnly Property hWnd As Integer Implements IContentsView.hWnd, IContentsView2.hWnd, IContentsView3.hWnd
        Get
            Return m_UserControl.Handle.ToInt32
        End Get
    End Property
    Public ReadOnly Property Name As String Implements IContentsView.Name, IContentsView2.Name, IContentsView3.Name
        Get
            Return "Localisation"
        End Get
    End Property
    Public WriteOnly Property ProcessEvents As Boolean Implements IContentsView.ProcessEvents, IContentsView2.ProcessEvents, IContentsView3.ProcessEvents
        Set(ByVal value As Boolean)
        End Set
    End Property
    Public Sub Refresh(item As Object) Implements IContentsView.Refresh, IContentsView2.Refresh, IContentsView3.Refresh
    End Sub
    Public Sub RemoveFromSelectedItems(item As Object) Implements IContentsView.RemoveFromSelectedItems, IContentsView2.RemoveFromSelectedItems, IContentsView3.RemoveFromSelectedItems
    End Sub
    Public Property SelectedItem As Object Implements IContentsView.SelectedItem, IContentsView2.SelectedItem, IContentsView3.SelectedItem
        Get
            Return Nothing
        End Get
        End Set
    End Property
    Public Property ShowLines As Boolean Implements IContentsView.ShowLines, IContentsView2.ShowLines, IContentsView3.ShowLines
        Get
        End Get
        Set(value As Boolean)
        End Set
    End Property
      Public ReadOnly Property Bitmap As Integer Implements IContentsView3.Bitmap
        Get
            Dim bitmapResourceName As String = Me.GetType().Name + ".bmp"
            Dim bmp As System.Drawing.Bitmap = New System.Drawing.Bitmap(Me.GetType(), bitmapResourceName)
            bmp.MakeTransparent(bmp.GetPixel(1, 1)) 'Utilise un png aléatoire avec transparence
            Return bmp.GetHbitmap().ToInt32()
        End Get
    End Property
     Public ReadOnly Property Tooltip As String Implements IContentsView3.Tooltip
        Get
        End Get
    End Property
    Public Property Visible As Boolean Implements IContentsView.Visible, IContentsView2.Visible, IContentsView3.Visible
        Get
            Return True
        End Get
        End Set
    End Property
End Class
by Anonymous User
Not applicable
Carl,
The contents view has changed a bit for ArcGIS 10.
The class implementing IContentsView3 must be registered in the 'Esri Contents Views' component category. You can see an example of this with the TOC Layer Filter Sample.
They can no longer be dynamically added or turned on/off with the visibility property.
As part of the transition from 9.x to 10, we were encouraging developers to move their TOC customization to dockable windows.
CarlTremblay
Thank you verry much ...
