I am running 10.1 Arc Server and we have several services published to the service. Tools in arcGIS Explorer Desktop call these services and display the results. And....everyone that published the former services no longer work here and I wasn't working here when they did. So I'm shooting in the dark hoping to hit something.
I have a service which runs in Arcmap without a problem. Once it finishes I publish the service to the server and push the new dll to the published library location.
In the client I get only 3 messages from the server (even though I'm putting out a TON of messages)
Running service.
Executing...
Failed.
Thank you very much for such explicite data ESRI!!
On the server I get a log message that looks like this:
VERBOSE Jan 9, 2014 3:02:56 PM GPServerSync.Deactivate CalculateDistances.GPServer
FINE Jan 9, 2014 3:02:56 PM String request successfully processed. Response size is 378 characters. CalculateDistances.GPServer
VERBOSE Jan 9, 2014 3:02:56 PM Save job message type SOAP message size 378 CalculateDistances.GPServer
VERBOSE Jan 9, 2014 3:02:56 PM Save job message type SOAP message size 374 CalculateDistances.GPServer
FINE Jan 9, 2014 3:02:56 PM String request received. Request size is 433 characters. CalculateDistances.GPServer
VERBOSE Jan 9, 2014 3:02:56 PM GPServerSync.Activate CalculateDistances.GPServer
FINE Jan 9, 2014 3:02:56 PM String request successfully processed. Response size is 406 characters. CalculateDistances.GPServer
FINE Jan 9, 2014 3:02:56 PM String request received. Request size is 384 characters. CalculateDistances.GPServer
FINE Jan 9, 2014 3:02:56 PM String request successfully processed. Response size is 385 characters. CalculateDistances.GPServer
FINE Jan 9, 2014 3:02:56 PM String request received. Request size is 380 characters. CalculateDistances.GPServer
FINE Jan 9, 2014 3:02:55 PM String request successfully processed. Response size is 385 characters. CalculateDistances.GPServer
FINE Jan 9, 2014 3:02:55 PM String request received. Request size is 380 characters. CalculateDistances.GPServer
FINE Jan 9, 2014 3:02:55 PM String request successfully processed. Response size is 396 characters. CalculateDistances.GPServer VERBOSE Jan 9, 2014 3:02:55 PM Job jbbc989cb7b08467b9e57d7c4a21db9e2 is successfully submitted. CalculateDistances.GPServer
So it looks like the job was successfully submitted, the parameters were received without a problem, the response appears to have been sent yet I see nothing that shows any failure!
I added a reference so that I could access ServerLogger and add my own logging to the log. But my messages do not show up here. And there is no process that I can find that I can attach to that lets me enter debug mode to debug my server code. Thank you very much again ESRI.
So how do I debug my service in this pile of failure that ESRI pretends is a server service??? How can I get my logging to work? How can I attach to something so I can debug my code and find out what is failing??? How can anyone publish a working service with so many roadblocks to debugging placed in front of us by ESRI???!!!!
Thanks
