Hi all,
I try to update metadata using ArcObjects. This is easy for simple properties such as "dataIdInfo/idCitation/resTitle" using IPropertySet.SetProperty(Name, Value). But I can't find any information or example, how to add values for multivalue-properties such as "dataIdInfo/themeKeys/keyword".
This works (code snippet):
pMetaData = pDatasetName
Dim pPropSet As IPropertySet
pPropSet = pMetaData.Metadata
pPropSet.SetProperty("dataIdInfo/idCitation/resTitle", "Test1")
pMetaData.Metadata = pPropSet
But I want to write a few tags:
dataIdInfo/themeKeys/keyword: AAA
dataIdInfo/themeKeys/keyword: BBB
The result of:
pPropSet.SetProperty("dataIdInfo/themeKeys/keyword", "AAA")
pPropSet.SetProperty("dataIdInfo/themeKeys/keyword", "BBB")
is this:
Tags:
BBB, BBB, BBB, BBB, BBB, BBB, BBB
All tags contained so far have been replaced with the last keyword (there were 7 tags before).
Also this don't work (ArgumentException):
Dim pNames(1), pValues(1) As String
pNames(0) = "dataIdInfo/searchKeys/keyword"
pNames(1) = "dataIdInfo/searchKeys/keyword"
pValues(0) = "AAA"
pValues(1) = "BBB"
pPropSet.SetProperty("dataIdInfo/searchKeys/keyword", pValues)
Or this (ArgumentException):
pPropSet.SetProperties(pNames, pValues)
How to deal with it?
