How to return a FeatureClass or FeatureDataset from an SOE?
6116
12-24-2014 06:54 AM
JustinShepard
I'm using arcobjects to build an SOE and need to return a feature collection. The examples that I've found online focus on returning a single geometry result in json format. Since my result will potentially have hundreds of features and I'll need the attributes as well as the geometry I'm wondering if there is a standard way of returning a FeatureClass. Ultimately this SOE will likely be used in a .NET Runtime application so I want to make sure that the results are easy to import into an application.
I will also have a couple of informational results to return, so I would like to set up the results something like:
      informationalResult1={}
      informationalResult2={}
      featureClassResult={}
Right now I'm thinking that I'll have to create JsonObjects for each result category and have each exist within a larger results JsonObject. If that is the case is there a recommended way to convert an entire FeatureClass to a JsonObject?
Thanks.
GregMcQuat
Hi, Justin. I think your approach using the Convert would probably be fine as long as the client knows what format to expect. You might consider converting the Feature Class to a Record Set and then converting it to JSON using SOESupport. I've put the example together from a couple of different sources though I haven't tried it. Good luck!
public static string FeatureClassToJSON(IFeatureClass pFeatureClass)
     ITable table = (ITable)pFeatureClass;
     IRecordSetInit rsInit = new RecordSetClass();
     IQueryFilter2 qf = new QueryFilterClass();
     rsInit.SetSourceTable(table, qf); // Load fc
     IRecordSet rs = rsInit as IRecordSet;
     byte[] jsonBytes = ESRI.ArcGIS.SOESupport.Conversion.ToJson(rs);
     return Encoding.UTF8.GetString(jsonBytes, 0, jsonBytes.Length);
Ref: bcdc spatial: Some random ArcObjects that make writing Server Object Extensions easier...(C#)
GregMcQuat
JustinShepard
It did throw an error when I tested it but it kept me with a few tweaks. I'm guessing that the silence from the rest of the community means that you and I are on the right track.
GregMcQuat
Fantastic! I'd appreciate seeing the working solution when you have it nailed down.
