Hi
Im using VS2008 and C# to run a GPProcess with a geoprocessor object. I need to access the IGPEnvironmentManager from the GeoProcessor object. In the old school (prior ArcGIS 9.2 and Visual Basic) this was simple because you created a gp object from the CreateObject("geoprocessing.gpdispatch.1") which was QI:able to the IGPComHelper which gives you access to the IGPEnvironmentManager.
How can I do this from the managed GeoProcessor object in C#?
