How to insert records into a shapefile from an excel sheet (c#.net)
1826
08-31-2010 10:08 PM
SolidSmoke
Cud anyone advise me how to insert records into the attribute table of an existing shapefile from an excel sheet
BerendVeldkamp
Does the Excel sheet contain coordinates? In that case, you could probably add it as an event layer to ArcMap, and then copy+paste features into an existing shapefile. The number and types of attributes should match, I suppose, but surely there are ways around that.
Of course this can be programmed in C# as well.
JamesCrandall
Use ADO.NET and setup an OLEDB Connection to the Excel spreadsheet, fill a DataTable, populate the shapefile attributes by going row-by-row thru the DataTable.
Edit: here's a bit of code for setting up the ADO.NET DataTable, connecting to the spreadsheet and filling a ADO.NET DataSet.  You can then begin to look at how to populate the shapefiles att's.
'Excel 2007
Dim ExcelConnection As New System.Data.OleDb.OleDbConnection("Provider=Microsoft.ACE.OLEDB.12.0;Data Source=C:\MyExcelSpreadsheet.xlsx;Extended Properties=""Excel 12.0 Xml;HDR=Yes""")
Dim objCmdSelect As OleDbCommand = New OleDbCommand(expr, ExcelConnection)
Dim objAdapter1 As OleDbDataAdapter = New OleDbDataAdapter()
Dim objDT As DataTable
Dim ds As New DataSet()
Using objCmdSelect
   objCmdSelect.Connection = ExcelConnection
   objAdapter1.SelectCommand = objCmdSelect
   objAdapter1.Fill(ds, "dtExcelData")
End Using
objDT = ds.Tables(0)
Dim ct As Integer
ct = objDT.Rows.Count 'make sure the DataTable was filled with rows
Once you have your ADO.NET DataTable object filled, you can then set the pFeatureClass to your shapefile/layer and use the IFeatureBuffer to add the attributes.  Something like this (just a snippet taken from one of my applications so this is untested):
Dim pFeatCur As IFeatureCursor
Dim pFeatBuf As IFeatureBuffer
pFeatBuf = pFeatureClass.CreateFeatureBuffer
pFeatCur = pFeatureClass.Insert(True)
Dim dtCol As DataColumn
Dim dtColname As String
Dim row As DataRow
For i = 0 To objDT.Rows.Count - 1
 row = objDT.Rows(i)
 '***add the rest of the attributes
                    For Each dtCol In objDT.Columns
                        dtColname = dtCol.ColumnName.ToString
                        Dim dtColType As String = dtCol.DataType.ToString
                        If Not IsDBNull(row.Item(dtColname)) Then
                            pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = row.Item(dtColname)
                        Else
                            If dtCol.DataType.FullName.ToString = "System.Int32" Then
                                pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = CInt(0)
                            ElseIf dtCol.DataType.FullName.ToString = "System.String" Then
                                pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = CStr("NA")
                            ElseIf dtCol.DataType.FullName.ToString = "System.Double" Then
                                pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = CDbl(0.0)
                            ElseIf dtCol.DataType.FullName.ToString = "System.Decimal" Then
                                pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = CDec(0.0)
                            ElseIf dtCol.DataType.FullName.ToString = "System.DateTime" Then
                                pFeatBuf.Value(pFeatBuf.Fields.FindField(dtColname)) = CDate(Now())
                            End If
                        End If
                   pFeatCur.InsertFeature(pFeatBuf)
      Else
       End If
 pFeatCur.Flush()
KonradDebski
Maybe this example will help you a bit:
http://www.esri.com/news/arcuser/0104/files/excel.pdf
