Dear all,I have two polygon feature classes, polygon A and polygon B.I would like to write a VBA to perform a select by location function to find out which polygon(s) in polygon B is/are intersect with a selected polygon in polygon A which is selected by a user. I know, I can use "ISpatialFilter" to do this, but don't know how to implement it in VBA. Would you mind provide some sample code/hints for me ?RegardsGary
Sub SpatialFilter() Dim pMxd As IMxDocument Set pMxd = ThisDocument Dim pEnumFeature As IEnumFeature Set pEnumFeature = pMxd.FocusMap.FeatureSelection pEnumFeature.Reset Dim pSearchFeature As IFeature Set pSearchFeature = pEnumFeature.Next If (pSearchFeature Is Nothing) Then MsgBox "Please select a feature to search." Exit Sub End If pMxd.FocusMap.ClearSelection Dim pLayer As ILayer Dim pSearchLayer As IFeatureLayer Dim pFeatureLayer As IFeatureLayer Dim i As Integer For i = 0 To pMxd.FocusMap.LayerCount - 1 Set pLayer = pMxd.FocusMap.Layer(i) If pLayer.Name = "Roads" Then Set pSearchLayer = pLayer Exit For End If Next If (pSearchLayer Is Nothing) Then MsgBox "Roads layer not found!" Exit Sub End If For i = 0 To pMxd.FocusMap.LayerCount - 1 Set pLayer = pMxd.FocusMap.Layer(i) If pLayer.Name = "Road Assets" Then Set pFeatureLayer = pLayer Exit For End If Next If (pSearchLayer Is Nothing) Then MsgBox "Road Assets layer not found!" Exit Sub End If Dim pSpatialFilter As ISpatialFilter Set pSpatialFilter = New SpatialFilter Dim pTopoOp As ITopologicalOperator Set pTopoOp = pSearchFeature.Shape ' You might need to buffer the search geometry in certain cases. ' Use a buffer value of 0 to search using the original geometry. Dim pSearchGeometry As IGeometry Set pSearchGeometry = pTopoOp.Buffer(10) Set pSpatialFilter.Geometry = pSearchGeometry pSpatialFilter.GeometryField = pSearchLayer.FeatureClass.ShapeFieldName pSpatialFilter.SpatialRel = esriSpatialRelIntersects Dim pFeatureCursor As IFeatureCursor Set pFeatureCursor = pFeatureLayer.Search(pSpatialFilter, False) Dim pFeature As IFeature Dim FeatureCount As Integer Set pFeature = pFeatureCursor.NextFeature Do While Not pFeature Is Nothing FeatureCount = FeatureCount + 1 pMxd.FocusMap.SelectFeature pFeatureLayer, pFeature Set pFeature = pFeatureCursor.NextFeature Loop If (FeatureCount = 1) Then MsgBox FeatureCount & " feature found." Else MsgBox FeatureCount & " features found." End If Dim pActiveView As IActiveView Set pActiveView = pMxd.FocusMap pActiveView.Refresh End Sub
Signed in members can post, follow updates, and more. New here? Register a free account.
