How to hide the symbols list in TOC control after creating layer layer
2042
05-30-2012 12:06 AM
AnatoliiTerentiev
After creating new layer and adding this layer to activeView,
in TOC control I see all symbols created. How I can hide the list of symbols?
Thanks in advance!
RichWawrzonek
You can collapse the legend for a feature layer in the TOC by using the ILegendInfo interface.
Assuming you have a pointer to a valid feature layer in the TOC called 'layer', here is a C# example:
ILegendInfo legendInfo = (ILegendInfo) layer;
legendInfo.get_LegendGroup(0).Visible = false; //COLLAPSE THE LEGEND
You may need to modify the index number depending on the properties of your layer.
AnatoliiTerentiev
Can't collapse layer, picture attached. Code:
      addLayerFromShapeFile(shapefileLocation, имяСлоя);
      featureLayer = getLayerByName(имяСлоя) as ESRI.ArcGIS.Carto.IFeatureLayer;
      geoFeatureLayer = (IGeoFeatureLayer)featureLayer;
      geoFeatureLayer.Renderer = getRenderer(имяСлоя);
      ILegendInfo legendInfo = (ILegendInfo)featureLayer;
In debugger I see
legendInfo.LegendGroupCount = 148
What is wrong?
AnatoliiTerentiev
If at least 1 legend group is visible, layer is expanded.
I solved problem by adding
for (int k = 0; k < legendInfo.LegendGroupCount; k++)
      legendInfo.get_LegendGroup(k).Visible = false;
