How to get the full path of a layer
1563
11-12-2019 02:00 PM
SusanFarley
I am trying to programmatically create a full copy of a layer on my map in ArcMap so that the user can run tools to clean up the data without mucking with the original in case they do something wrong. I have it working in ArcPro, but, because of speed issues, I am now trying to implement my cleanup tools in ArcMap. In ArcPro, my code looks like
var lyr = _arcFac.MainMapView.Map.GetLayersAsFlattenedList()
await QuededTask.Run(() =>
   foreach (BasicFeatureLayer fmLyr in lyr) {
         var hydLayer = fmLyr as FeatureLayer;
         var hydClass = hydLayer .GetFeatureClass();
         var hydStore = hydClass.GetDatastore();
         var hydPath = Path.Combine(hydStore.GetPath().LocalPath, hydClass.GetName());
         string newFileName = $"MergeLayer.shp";
         var mva = Geoprocessing.MakeValueArray(hydPath + ".shp", $@"{hydPath}" newFileName);
         var res2 = Geoprocessing.ExecuteToolAync("copy_Management", mva);
In ArcMap, I have
         IFeatureLayer hydLayer = selectedLayer[0];
         var hydClass = hydLayer .FeatureClass();
         var hydStore = hydClass.FeatureDataset(); //this is null
So, how do I get the full path of the selected layers? File.GetPath(selectedLayer[0]) get the correct path only if it is in the same path as the map and if you have saved the map.
Thank you,
Susan
DuncanHornby
MVP Notable Contributor
Try this code:
Public Sub GetPath()
 ' This sample code assumes the first layer in the map is a shapefile
 Dim pMXD As IMxDocument
 Set pMXD = ThisDocument
 Dim pMap As IMap
 Set pMap = pMXD.FocusMap
 Dim pLayer As ILayer
 Set pLayer = pMap.Layer(0)
 Dim pDataset As IDataset
 Set pDataset = pLayer
 Dim sPath As String
 Let sPath = pDataset.Workspace.PathName & "\" & pDataset.Name & ".shp"
 MsgBox sPath, vbOKOnly, "Full Path"
End Sub‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
