How to get Lat Lon?
1688
07-28-2011 10:11 AM
GregRieck
Hello,
I'm looking for a way to obtain the Lat Lon value as new feature classes are created no matter what the current map projection is. I have feature classes that contain attribute fields for storing the Lat Lon values as a string. I need to populate theses fields as features are created.
Is there a function available in the object model that allows me to do this?
Greg
NeilClemmons
Honored Contributor
If the geometry has a projected coordinate system then you should be able to just use the geographic coordinate system it's based on and project it.  The following is a code snippet from one of our apps.
                ' Project the UTM to Lat/Long.
                Dim projCoordinateSystem As IProjectedCoordinateSystem = DirectCast(point.SpatialReference, IProjectedCoordinateSystem)
                point.Project(projCoordinateSystem.GeographicCoordinateSystem)
                ' Update the DD textboxes.
                DdLatitudeTextbox.Text = Format(point.Y, "0.000000")
                DdLongitudeTextbox.Text = Format(point.X, "0.000000")
GregRieck
Thanks Neil that's what I was looking for. Do you have a way to handle polygons by returning the lat lon of the centroid of the polygon?
Greg
NeilClemmons
Honored Contributor
Project the polygon just like this code projects the point.  Then QI from IPolygon to IArea and use the Centroid property.
GregRieck
Thanks Neil, I knew that, just spaced it. I added a trap to make sure it's a Projected Coordinate System
      IPolygon pg = MyFeature.Shape as IPolygon;
      if (pg.SpatialReference is IProjectedCoordinateSystem)
        projCoordinateSystem = pg.SpatialReference as IProjectedCoordinateSystem;
        pg.Project(projCoordinateSystem.GeographicCoordinateSystem);
        // Update the DD textboxes.
        IArea area = pg as IArea;
        obj.set_Value(gpslatitude, string.Format("{0:0.######}", area.Centroid.Y));
        obj.set_Value(gpslongitude, string.Format("{0:0.######}", area.Centroid.X));
