how to crop (cut) a map using ArcObjects???
1733
6
05-23-2010 12:29 AM
AbdulrahmanAlqasim
hello everyone
im new to the field of Arcobjects.
i need to create a tool for clipping (crop) a map with predefined dimensions. the user has to select only where to crop.
1- the user press button
2- rectangle is drawn over the map with specific dimension
3- the user can move the rectangle and then press OK
4- a new layer contains the cropped map is added
please guys i need a hand on this issue. at least give guide lines
thank you
AbdulrahmanAlqasim
guys, any clue, hint or link is much appreciated
JamesCrandall
What is the application type (ArcEngine, ArcServer, ArcMap)?
I can probably give some help regarding numbers 1-3, but I don't understand what you want to do with #4 at all.
AbdulrahmanAlqasim
hi jamesfreddyc
im using Arcmap
i want to add new layer or save the new map as a tiff file. it doesnt matter. the important thing is that i want to give the user the ability to crop the map and save it as a file.
i really appreciate ur help
thank you
JamesCrandall
hi jamesfreddyc
im using Arcmap
thank you
I have not attempted to implement this functionality, but here's a sample from ArcGIS v9.0 that would probably work for you...
http://edndoc.esri.com/arcobjects/9.2/CPP_VB6_VBA_VCPP_Doc/COM_Samples_Docs/Cartography/Printing_and...
AlexanderGray
Honored Contributor
Putting a map object inside a layer object is not really possible (for a number of reasons.)  I suggest you look at the IExport interface.  There is a sample on how to create a jpeg from activeView (a lot of the same methods would be required for tiff.)  There are methods for specifying the rectangle (extent) of the active view.
AbdulrahmanAlqasim
jamesfreddyc thank you for the link.. i will try it
agray1: yes u r right, but i mean to add tiff image as layer ( not map)  . sorry im still beginner
