How to create a coordinate system with a user defined datum (i.e. with dx, dy, dz)
1711
06-16-2010 10:45 PM
by Anonymous User
Not applicable
Original User: gershon
I'm developing a C# application with an ESRI map engine.
One of my requirements is to enable the user to define custom Datum with 3 parameters (linear shift) to be used within some Coordinate Systems.
A small sample will be appreciated  🙂
by Anonymous User
Not applicable
Original User: mkennedy
It's a lot easier if you can use existing geographic coordinate systems/datums. Geographic (datum) transformations are maintained separately from the geographic coordinate systems (GCS). A pair of GCS may have many possible  transformations based on different areas of interest, accuracies, etc.
I'm including some C# code that creates a custom 7-parameter transformation. For a 3 parameter, use the GeocentricTranslation class instead.
You will likely also need to cast back to IGeoTransformation.
Melita
    // Initialize a new spatial reference environment.
    // SpatialReferenceEnvironment is a singleton object and needs to use the Activator class.
    Type factoryType = Type.GetTypeFromProgID("esriGeometry.SpatialReferenceEnvironment");
    System.Object obj = Activator.CreateInstance(factoryType);
    ISpatialReferenceFactory2 pSRF = obj as ISpatialReferenceFactory2;
    // Initialize and create the input and output coordinate systems.
    IProjectedCoordinateSystem2 pPCSin = new ESRI.ArcGIS.Geometry.ProjectedCoordinateSystemClass();
    IProjectedCoordinateSystem2 pPCSout = new ESRI.ArcGIS.Geometry.ProjectedCoordinateSystemClass();
    pPCSin = (IProjectedCoordinateSystem2)pSRF.CreateProjectedCoordinateSystem((int)esriSRProjCSType.esriSRProjCS_Abidjan1987UTM_30N);
    pPCSout = (IProjectedCoordinateSystem2)pSRF.CreateProjectedCoordinateSystem((int)esriSRProjCSType.esriSRProjCS_WGS1984UTM_30N);
    IGeographicCoordinateSystem2 pGCSto;
    IGeographicCoordinateSystem2 pGCSfrom;
    // Retrieve the geographic coordinate systems from the
    // two projected coordinate systems
    pGCSfrom = (IGeographicCoordinateSystem2)pPCSin.GeographicCoordinateSystem;
    pGCSto = (IGeographicCoordinateSystem2)pPCSout.GeographicCoordinateSystem;
    // Initialize and create an appropriate geographic transformation.
    ICoordinateFrameTransformation pCFT;
    pCFT = new CoordinateFrameTransformationClass();
    pCFT.PutParameters(1.234, -2.345, 658.3, 4.3829, -2.48591, 2.18943, 2.48585);
    pCFT.PutSpatialReferences(pGCSfrom,pGCSto);
    pCFT.Name = "Custom GeoTran";
