How to check if a module exist
4637
06-02-2010 01:36 AM
chriss_
Hi!
I'm programming in VBA. What I want to do is, to call a module, but only if it already exists. Is there any possibillity to check in vba if a module (Eg. "module1) exists in my project (eg. project1)?
Actually i also would be interested in the same for shapefiles. Any possibility to check if a shapefile does already exist? any ideas?
Thanks
Chris
KirkKuykendall
try this (VBE is documented somewhere at Microsoft)
Option Explicit
Sub TestModExists()
    Debug.Print ModExists("ArcID")
    Debug.Print ModExists("xxx")
End Sub
Function ModExists(name As String) As Boolean
    ModExists = False
    Dim pVBE As VBIDE.VBE
    Set pVBE = Application.VBE
    Dim l As Long
    For l = 1 To pVBE.VBProjects.Count
        Dim k As Long
        For k = 1 To pVBE.VBProjects(l).VBComponents.Count
            If pVBE.VBProjects(l).VBComponents(k).Type = vbext_ct_StdModule Then
                Dim s As String
                s = UCase(pVBE.VBProjects.Item(l).VBComponents(k).name)
                If s = UCase(name) Then
                    ModExists = True
                    Exit Function
                End If
            End If
        Next k
    Next l
End Function
chriss_
Hi Kirk!
Thank you for answering my questions again. Great
Best regards
Chris
