how to change symbol (fill, color etc) on selected features only
1463
07-12-2012 09:12 AM
RinatSolorzano_Palero
Hi everyone, i would like to know how to change the symbol properties on the selected features only, i want to fill it with linefillsymbol. Here's some code i've done but it doesnt work
Dim pFSel As IFeatureSelection
Set pFSel = pMap.Layer(0)
Dim pSelSet As ISelectionSet2
Dim pFeature As IFeature
Dim pFcursor As IFeatureCursor
Set pSelSet = pFSel.SelectionSet
pSelSet.Search Nothing, False, pFcursor
Set pFeature = pFcursor.NextFeature
Dim a As IFeatureRenderer
Dim pLSymbol As ILineFillSymbol
Set pLSymbol = New LineFillSymbol
Set a = pGFLayer.renderer
Set pLSymbol = a.SymbolByFeature(pFeature)
Dim pColor As IRgbColor
Set pColor = New RgbColor
pColor.RGB = RGB(255, 0, 0)
pLSymbol.color = pColor
pLSymbol.Separation = 7
pLSymbol.Angle = 70
'Dim padisplay As IDisplay
'Set padisplay = pMxDoc.ActiveView.ScreenDisplay
'padisplay.SetSymbol pLSymbol
'a.Draw pFcursor, esriDPSelection, padisplay, Nothing
pMxDoc.UpdateContents
pMxDoc.ActiveView.Refresh
thnks a lot!!
PeterYurkosky1
IFeatureRenderer.SymbolByFeature returns a copy of a symbol. So all this code is doing is copying a renderer's symbol and then changing the copy. Even if it were "by-reference", you'd be modifying the symbol for all features that use that symbol, whether they're selected or not. That's surely not what you want.
I'd suggest looping over the cursor you got from the selection set and drawing the symbol directly via ISymbol.Draw.
hi!, i've tried with the draw function from IFeatureRenderer using the cursor i have like this:
pLSymbol.Angle = 70
but i get an automation error, i'm not sure where's the mistake.... thanks for your help!!
