How to change programmatically the data source (FeatureClass-property) of IFeatureLayer with DataSourceType = "Query Feature Class" in ArcMap 10.3 ?
4171
03-16-2016 09:49 AM
ThomasKoch
Hi all,
I have a Feature-Layer pointing to an Oracle Table (user-maintained rowid) with spatial type "SDO_GEOMETRY". The Oracle Table is not SDE-registered. By both loading the table from ArcCatalog into ArcMap or using ArcTool MakeQueryLayer I get a layer with data type "Query Feature Class".
Map operations e.g. zooming, panning, selecting etc. work.
My issue is changing the data source programmatically (c#, ArcMap 10.3) either results to exceptions or a layer with data type "Feature Class" and consecutively drawing errors in ArcMap when loading additional layers and executing map operations e.g. zooming, panning, selecting etc:
Drawing errors also occur when I create this layer by ArcTool MakeFeatureLayer although when loaded stand-alone, i.e. no additional layer are load in TOC, map operations e.g. zooming, panning, selecting etc. work without any errors.
Input: IFeatureWorkspace featureWS (cast from IWorkspace with Type = esriRemoteDatabaseWorkspace)
Input: IFeatureLayer pFeatureLayer
  • DataSourceType: Query Feature Class
  • FeatureClass: with AliasName "schema1.%Table1" (what does the character "%" mean ?? / where does this character come from ?? My table's name is "schema1.Table1" !!)
#region Alternative 1: IQueryDef => System.Runtime.InteropServices.COMException (0x80050140): Abstract Data Types not supported
IQueryDef queryDef = featureWS.CreateQueryDef();
queryDef.Tables = "schema1.Table1";
queryDef.SubFields = "*";
queryDef.WhereClause = string.Empty;
IFeatureDataset pFeatureQuery =
    featureWS.OpenFeatureQuery("Table1", queryDef);
pFeatureLayer.FeatureClass = pFeatureQuery as IFeatureClass;
#endregion
#region Alternative 2: ITable zu IDataset => Data Source Type = FeatureClass => Drawing Error in ArcMap
ITable table = featureWS.OpenTable("schema1.Table1");
IDataset dataSet = table as IDataset;
pFeatureLayer.FeatureClass = dataSet as IFeatureClass;
pFeatureLayer.DataSourceType = "Query Feature Class";
#endregion
So my question is how to change programmatically the data source (FeatureClass-property) of IFeatureLayer with DataSourceType = "Query Feature Class" in ArcMap 10.3 avoiding the change of DataSourceType, any exceptions and drawing errors ?
Any help is appreciated !
OlivierDamanet
I don't know if you are still looking for a solution here, but here is how I set data source of Query Layers programmatically:
ISqlWorkspace sw = featureWS as ISqlWorkspace;
string query = string.Format("SELECT * FROM {0}", tableName);
IQueryDescription queryDesc = sw.GetQueryDescription(query);
queryDesc.OIDFields = tableID; string queryClassName = "";
//get a unique name for this Query Class
sw.CheckDatasetName(tableName, queryDesc, out queryClassName);
IFeatureClass featureClass = sw.OpenQueryClass(queryClassName, queryDesc) as IFeatureClass;
featureLayer.FeatureClass = featureClass;
Hope this helps
