How to add Annotation Layer to ArcMap from CAD file
1646
03-11-2013 07:08 AM
AntonPerlov1
I need to add Annotation Layers from .dwg and .dgn CAD files to arcmap
At first I used Block of code like this
ESRI.ArcGIS.Geodatabase.IWorkspaceFactory pWorkspaceFact = new
                 ESRI.ArcGIS.DataSourcesFile.CadWorkspaceFactory();
                //Open the workspace.
                ESRI.ArcGIS.Geodatabase.IWorkspace pWorkspace = pWorkspaceFact.OpenFromFile
                    (workspace_path, 0);
                ESRI.ArcGIS.Geodatabase.IFeatureWorkspace pFeatureWorkspace =
    (ESRI.ArcGIS.Geodatabase.IFeatureWorkspace)pWorkspace;
 IGroupLayer cl = new GroupLayerClass();
            cl.Name = fc_name;
                IAnnotationLayerFactory lf = new FDOGraphicsLayerFactory() as IAnnotationLayerFactory;
                IAnnotationLayer al= lf.OpenAnnotationLayer(pFeatureWorkspace, null, System.String.Concat(fc_name,":Annotation"));
                cl.Add(al as ILayer);
but this code generates Annotation Layer with broken emty datasource. And datasource cannot be set from CAD manually.
There also is interface
EngineCadAnnotationLayerFactory and CoClass EngineCadAnnotationLayerFactoryClass, but they only implement ILayerFactory interface, not the IAnnotationLayerFacory interface. This trouble makes unreachable OpenAnnotationLayer() method.
Can anyone help me to find solution?
LeoDonahue
hang on... posted the wrong thing, looking it up again..
AntonPerlov1
The solution is finally found
                CadAnnotationLayerClass newlayer = new CadAnnotationLayerClass();
                newlayer.DataSourceType = "CAD Annotation Feature Class";
                newlayer.Name = "Аnnotations";
                newlayer.FeatureClass = pFeatureWorkspace.OpenFeatureClass(System.String.Concat(fc_name, ":Annotation")); ;
