How Intersect (Analysis) works - So How Do I Use It?
2558
7
06-13-2011 11:55 AM
DougMarquardt
Found this link in the docs that talks about exactly what I need to do:
http://edndoc.esri.com/arcobjects/9.2/NET/shared/geoprocessing/analysis_tools/how_intersect_analysis...
But I can't find any code examples, etc on actually doing this?
I have a polygon and a polyline and I want to get the intersects between the two.
Is this functionality even available with .Net and ArcGISEngine 10?
Can someone please point me in the right direction here.
Doug.
DougMarquardt
Well, I did find some info on ESRI.ArcGIS.AnalysisTools.Intersect but no code examples.
I tried this but nothing happens...
                    Dim shpL As New List(Of Object)
                    shpL.Add(plyLine)
                    shpL.Add(plyGon)
                    Dim shpLI As Object = Nothing
                    Dim isect As New ESRI.ArcGIS.AnalysisTools.Intersect(shpL, shpLI)
                    shpLI = isect.out_feature_class
Can someone provide a code example on using ESRI.ArcGIS.AnalysisTools.Intersect?
Doug.
KenBuja
MVP Esteemed Contributor
Take a look at this thread on how to set up the Geoprocessor for the Analysis Tools. If I ever have trouble in setting up the code to run a tool, I run the tool manually and examine the results page to see what the syntax looks like.
ESRICustomer
Doug.
I don't know anything about Analysis services, but I am calculating intersections, overlapping areas, etc, with ITopologicalOperator4, IRelationalOperator, IProximityOperator, and IGeometry5.  For an intersection for example, I simply take an IFeature.Shape and intersect it with another IFeature.Shape...
Friend Function GetIntersectedPolygon(ByVal OtherPolygon As IGeometry5) As IGeometry5
Dim intersectedGeometry As IGeometry5 = Nothing
intersectedGeometry = ITopologicalOperator4.Intersect(OtherPolygon, esriGeometryDimension.esriGeometry2Dimension)
Return intersectedGeometry
End Function
DougMarquardt
Hi kenbuja,
I can't run any tool manually as I am only licensed for ArcGISEngine.
The example helped a bit, but I still need to know how to pass a 'list' of objects in to the in_features parameter....
Doug.
DougMarquardt
I finally got this thing working 😄
Here is code example of what I did in case it helps anyone else:
                Dim gp As New ESRI.ArcGIS.Geoprocessor.Geoprocessor
                gp.SetEnvironmentValue("workspace", wksp.PathName)
                Dim s As String = ""
                Dim vt As ESRI.ArcGIS.Geoprocessing.IGpValueTableObject = New ESRI.ArcGIS.Geoprocessing.GpValueTableObjectClass()
                vt.SetColumns(2)
                s = GetPathForALayer(MyPolygonLayer)
                vt.AddRow("'" & s & "' 1")
                s = GetPathForALayer(MyPolylineLayer)
                vt.AddRow("'" & s & "' 2")
                Dim fcname As String = "my_intersect_" & MyID & "_" & Guid.NewGuid.ToString.Replace("-", "")  'Uses a guid to ensure unique name
                s = System.IO.Path.Combine(wksp.PathName, fcName)
                Dim pVarArray As IVariantArray = New VarArrayClass()
                pVarArray.Add(vt)
                pVarArray.Add(s)
                gp.Execute("intersect_analysis", pVarArray, Nothing)
                Dim fWk As IFeatureWorkspace = wksp
                Dim fcTmp = fWk.OpenFeatureClass(fcname)
Cheers!
DougMarquardt
End Function
I've posted a solution that I finally got working, but your solution seems interesting and I will check it out.
Thanks.
KenBuja
Here's another way to do it
       IGPUtilities2 gpUtils = new GPUtilitiesClass();
       IFeatureClass inFeature1 = gpUtils.OpenFeatureClassFromString(@" ");//path of the 1st Input Feature Class
       IFeatureClass inFeature2 = gpUtils.OpenFeatureClassFromString(@" ");//path of the 2nd Input Feature Class
       IFeatureClass inFeature3 = gpUtils.OpenFeatureClassFromString(@" ");//path of the 3rd Input Feature Class
       Test(inFeature1, inFeature2, inFeature3);
       private void Test(IFeatureClass pf1,IFeatureClass pf2,IFeatureClass pf3)
            try
                ESRI.ArcGIS.Geoprocessor.Geoprocessor GP = new ESRI.ArcGIS.Geoprocessor.Geoprocessor();
                GP.OverwriteOutput = true;
                IGpValueTableObject vt = new GpValueTableObjectClass();
                vt.SetColumns(2);
                object weight;
                weight = 1 as object;
                object obj1 = pf1;
                vt.AddRow(ref obj1);
                vt.SetValue(0, 1, ref weight);
                object obj2 = pf2;
                vt.AddRow(ref obj2);
                vt.SetValue(1, 1, ref weight);
                object obj3 = pf3;
                vt.AddRow(ref obj3);
                vt.SetValue(2, 1, ref weight);
                ESRI.ArcGIS.AnalysisTools.Intersect intersect = new ESRI.ArcGIS.AnalysisTools.Intersect();
                intersect.in_features = vt;
                intersect.out_feature_class = @"D:\Neil'sData\Output\New1.shp";//Specify The Output path
                GP.Execute(intersect, null);
                MessageBox.Show("Intersection is Successfull!!!!!!");
            catch (Exception e1)
                MessageBox.Show("error!!!!");
