How I can gen layer by name?
5191
8
03-09-2011 02:31 AM
AnatoliiTerentiev
c#+.net+arcgis Engine
I can gen layet by index?, for example - MapControl1.get_Layer(8)
Can't anybody say how I can get layer by name?
Thanks for any help or reference!
JanBurdziej1
You can loop through all layers and check names.
Example in vb.net:
        ' Enumerate layers
        pEnumLayers = pMap.Layers
        pEnumLayers.Reset()
        pLayer = pEnumLayers.Next()
        Do Until pLayer Is Nothing
                      If pFLayer.Name = [layer name] Then
                        Exit Do
                    End If
        Loop
Regards,
Jan
AnatoliiTerentiev
Thank you very much!
AnatoliiTerentiev
But if there are some composite layer?
AlexanderGray
Honored Contributor
The imap.layers method has a recursive boolean argument as the second argument.  That looks into composite layers.
MichaelRobb
Honored Contributor
You can check if its a group layer,  then cycle through the composite layers within that group.
example here:
 For j = 0 To pMap.LayerCount - 1
                        GetName = pMap.Layer(j).Name
                        'One level in
                        If TypeOf pMap.Layer(j) Is ESRI.ArcGIS.Carto.IGroupLayer Then
                            pCompositeLayer = pMap.Layer(j)
                            For g = 0 To pCompositeLayer.Count - 1 'cycle through the composite layer
                                'GET THE NAME of each layer here
                        End If
AnatoliiTerentiev
I can't find how to define that layer is group or composite layer in c#.
if (map.get_Layer(i).GetType() ==  ESRI.ArcGIS.Carto.IGroupLayer ??? ) ...
Can anybody help? Thanks!
vincentLahaye
hi,
if I remember it's :
if (map.get_Layer(i) is ESRI.ArcGIS.Carto.IGroupLayer)
you can use this link to compare VB and C#, if you need to translate code :
http://www.harding.edu/fmccown/vbnet_csharp_comparison.html
Vincent
MichaelRobb
Honored Contributor
I will REPOST what I posed:
its in my above post:
