How do you access the output of iGpDispatch.ListIndexes method in VB.net?
967
06-26-2011 10:47 AM
NicholasReseburg1
Hello.  I am working on a program that will list the indexes in a featureclass.  I am trying to use the iGpDispatch method of the geoprocessing object.  I think I am doing good up to the point where I run the actual ???listindexes??? method.  I am not how to handle the results of this method.
Do I dim an object and set it to the value of pGpDispatch?  Like
dim objObject as pGpDispatch.listindexes(pGxObject)???
and then just type for each index in objObject.index
strIndex = objObject.Nameetc.
or do I need to do a
With  pGpDispatch.listindexes(pGxObject)
and then get the properties I want?  I played around with several ways, but the lack of IntelliSense suggestions leads me to believe I am wrong.
Here is the code I have so far.  Currently it is a standalone windows form executable so I am getting the feature class from a GxDialog and making it into a GxOBject.
Any suggestions on ways to go would be most appreciated!
Code:
Imports ESRI.ArcGIS.Catalog
Imports ESRI.ArcGIS.CatalogUI
Imports ESRI.ArcGIS.Geoprocessing
Public Class IndexBuilder_Startup
    Private Sub cmdGetFC_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdGetFC.Click
        Dim pEnumGX As IEnumGxObject
        Dim pGxDialog As IGxDialog = New GxDialogClass
        With pGxDialog
            .Title = "Choose File To Search For Indexes On"
            .StartingLocation = ???\\DataDrive\???
            .ObjectFilter = GetFilter()
        End With
        If Not pGxDialog.DoModalOpen(0, pEnumGX) Then
            Exit Sub
        End If
        Dim objGxObject As IGxObject = pEnumGX.Next
        TextBox1.Text = objGxObject.Name
        Dim gp As IGeoProcessor
        gp = New GeoProcessor
        Dim pDispatch As IGpDispatch
        pDispatch = gp
        '' This is where i am stuck.
        objGxObject = pDispatch.ListIndexes(objGxObject)
        For Each index In objGxObject.index
    End Sub
    Private Function GetFilter() As Object
       Dim objFilter As IGxObjectFilter = New GxFilterPGDBFeatureClasses
        Return objFilter
    End Function
YaminiManickam
Here is a VBA sample that demonstrates the use of ListIndexes function:
How to list indexes - http://help.arcgis.com/en/sdk/10.0/vba_desktop/conceptualhelp/index.html#//00010000012v000000
For more information on the function, please see:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v0000001r000000.htm
I hope this helps.
