How can I sign an Addin with signtool?
1684
04-30-2013 05:08 AM
MikaelRittri
I am trying to sign an AddIn. I cannot easily use the ESRISignAddIn utility, because our ArcMap license is not on the same computer as the one with our certificates. So I tried to use signtool on the certificate computer, like this:
I moved the dll files of my AddIn to the certificate computer, where I signed them with signtool. Then I moved them back to the ArcMap computer. I opened the the .esriaddin file in WinZip, removed the unsigned dll files, and inserted their signed variants.
Now, when I check the properties of the dll files, they have been successfully signed.
But when double-clicking the modified .esriaddin file, the ESRI ArcGIS Add-In Installation Utility still claims that
   "This Add-In file is not digitally signed".
So it is not enough that the dll files are signed. But as far as I know, the signtool command can only sign dll files, exe files, and few other kinds of files, not an entire .esriaddin file.
Any advice would be welcome.
ChristophKoschmieder
Any new information or changes on that topic in the last over 10 years?! I am facing the same problem with signing ArcGIS Pro AddIns and Configuations using the signtool by the command line.
Any suggestions would be warmly welcome!
