How can I find out if the layer IDs are fixed in mxd through ArcObjects?
1667
03-02-2017 05:40 AM
RafaelDetoni
I would like to know how can I find out if the layer IDs are fixed in mxd through ArcObjects? I usually use the code below to find the layer ids in mxd:
IMapDocument mapDocument = new MapDocumentClass();
mapDocument.Open("C:\\Temp\\MyProject.mxd");
IMap b = mapDocument.get_Map(0);
ILayerExtensions c = b.get_Layer(0) as ILayerExtensions;
IServerLayerExtension g = c.get_Extension(0) as IServerLayerExtension;
IPropertySet psN = new PropertySet();
psN.GetProperty("ServiceLayerID");
But when the ids are not fixed the returned Layer ID is wrong, because it follows the order of the layers included in the mxd.
By fixed ids i mean the configuration of Data Frame Properties General tab, when you check the box "Allow assignement of unique numeric IDs for map service publishing"
MichaelWidmer
Hi Rafael
Did you ever find a solution for this question? I'm currently struggling through the API documentation to find any a crumble of the mentioned information.
Cheers,
Michael
