Highlight\Select Table in Source TOC, VBA
3211
08-20-2010 09:09 AM
PatriciaPendleton
Hi all,
I am trying to figure out how to highlight/select an Excel table on the Source tab (using VBA) that has been programatically added to the map document through a form.  The goal is then to take the selected table and automatically export it to a file GDB (the equivalent of right-clicking on the table>Data>Export)...but first the table must be selected in the TOC!
I've tried embedding it directly into the button_click code, I've tried adding it as a called sub-routine, I have found several posts on the forums and items in the EDN that refer to this process, but none of it has quite gotten me there yet.  Pardon my newbie-ness and any blatant errors I am making :confused:.  Thanks in advance for any help you can give me!
Working code that adds an Excel table to map document and switches TOC view to source tab:
Private Sub CommandButton1_Click()
If txtExcel.Text = "" Then
MsgBox "Please put The Excel Files"
Exit Sub
ElseIf List3.ListCount = 0 Then
MsgBox "You have not selected any fields to display.", vbExclamation, "No Fields Available"
Exit Sub
End If
  Dim myPath As String
  myPath = txtExcel.Text 'excel path location
  connStr = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
              "Data Source = " & myPath & ";" & _
              "Extended Properties=""Excel 8.0;HDR=YES;"""
  Dim pPropset As IPropertySet
  Set pPropset = New PropertySet
  pPropset.SetProperty "CONNECTSTRING", connStr
  '++ connect to database
    Dim pWorkspace As IFeatureWorkspace
    Dim pWorkspaceFact As IWorkspaceFactory
    Set pWorkspaceFact = New OLEDBWorkspaceFactory
    Set pWorkspace = pWorkspaceFact.Open(pPropset, 0)
    If pWorkspace Is Nothing Then Exit Sub
    For i = 0 To List1.ListCount - 1 'select sheet
        If List1.Selected(i) = True Then
        Dim sheet As String
            sheet = (List1.List(i))
        End If
    Dim pTable As ITable
    Set pTable = pWorkspace.OpenTable(sheet)
    If pTable Is Nothing Then
    MsgBox "The table was not found"
    Exit Sub
    End If
 '++ Create a table collection and assign the new table to it
      MsgBox "Table added", vbInformation
      Dim pStTab As IStandaloneTable
      Dim pStTabColl As IStandaloneTableCollection
      Dim pMap As IMap
      Dim pMxDoc As IMxDocument
      Set pMxDoc = ThisDocument
      Set pMap = pMxDoc.ActiveView.FocusMap
      Set pStTab = New StandaloneTable
      Set pStTab.Table = pTable
      Set pStTabColl = pMap
      If Not TypeOf pTable Is IStandaloneTable Then
      pStTab.Name = Replace$(pStTab.Name, "$", "", 1, -1, vbTextCompare)
      End If
      pStTabColl.AddStandaloneTable pStTab
      pMxDoc.UpdateContents
 'Switch TOC view to Source Tab
 Call SetContentsView("Source")
End Sub
One failed attempt at setting the table as the selected/highlighted item:
Dim pContView As IContentsView
Set pContView = pMxDoc.ContentsView(1)  ' Source view
Set pContView.ContextItem = pStTab '--->Get "Object Required" error message
Another failed attempt at setting the table as the selected/highlighted item:
Referred to:
http://forums.esri.com/thread.asp?t=67188&f=992&c=93
and
http://edndoc.esri.com/arcobjects/9.0/ComponentHelp/esriArcMapUI/IContentsView_SelectedItem_Example....
Dim pStandaloneTable As IStandaloneTable
Dim pEnumStandaloneTable As IEnumStandaloneTable
Set pMxDoc = Application.Document
Set pMap = pMxDoc.FocusMap
Set pEnumStandaloneTable = pMap.Layers(, True)   '--->Results in Type Mismatch Error (Run-time error 13)
pEnumStandaloneTable.Reset
Set pStandaloneTable = pEnumStandaloneTable.Next
  Do Until pStandaloneTable Is Nothing
    If pStandalone.Name = pStTable.Name Then  ' this is the layer I want to activate/select
      pContView.ContextItem = pStandaloneTable
      Exit Do
    End If
  Loop
Thank You in Advance,
Patricia Pendleton
Cal State University, Northridge
Dept. of Geography
Center for Geographical Studies
PatriciaPendleton
Nevermind, answered my own question.  Spent a week trying to figure this out, only to get it as soon as I posted...
 'Activate Excel Table
Dim pTOC As IContentsView
Set pTOC = pMxDoc.ContentsView(1)  ' Source view
 pTOC.RemoveFromSelectedItems pTOC.SelectedItem
pTOC.AddToSelectedItems pStTab
