Hide Legend in the TOC
1263
05-15-2012 11:11 PM
AnikaMeyer
Dear all:
With the following code I would like to hide the legend in the TOC but it doesn't work. I wonder what I may do wrong. I am migrating my code from VBA (ArcGIS 9.2) to VB.Net in the Microsoft Visual Studio 2010 Programm.
I put you the new code. Perhaps you may help.
Thank you in advance.
Anika Meyer
            Dim pMXDoc As IMxDocument
            pMXDoc = My.ArcMap.Document
            Dim pMap As IMap
            pMap = pMXDoc.FocusMap
            Dim numLayer As Integer
            numLayer = pMap.LayerCount
            Dim pLayer As ILayer
            Dim pCadLayer As ICadDrawingLayers
            Dim pLegendInfo As ILegendInfo
            Dim pLegendGroup As ILegendGroup
            pLayer = pMap.Layer(1)
            pLayer.Visible = False
            If Not pLayer Is Nothing And (TypeOf pLayer Is ICadDrawingLayers) Then
                pCadLayer = pLayer
                pLegendInfo = pCadLayer
                pLegendGroup = New LegendGroup
                pLegendGroup = pLegendInfo.LegendGroup(0)
                pLegendGroup.Visible = False
                'Else
                'MsgBox("Layer not found or invalid: " & sname)
            End If
RichWawrzonek
Try replacing the following three lines:
with this one:
LengendInfo.LegendGroup(0).Visible = False
AnikaMeyer
Thank you very much Rich. But the problem seems to lie in the index of the legendgroup. For a CAD-Layer the legend is more complex. Trying the following code it now works.
                        For intLegendIndex = 0 To pLegendInfo.LegendGroupCount - 1
                            pLegendGroup = pLegendInfo.LegendGroup(intLegendIndex)
                        Next intLegendIndex
Kind regards,
Anika
The whole code looks like this:
    Public Sub LeyendasVisibilidadForum()
        Try
            Dim pMap As IMap
            Dim i As Integer
            Dim intLegendIndex As Integer
            Dim strPolygon1 As String = "*Polygon*"
            Dim strPolygon3 As String = "*Point*"
            Dim strPolygon4 As String = "*Polyline*"
            Dim strPolygon5 As String = "*MultiPatch*"
            Dim strPolygon6 As String = "toponaa1"
            For i = 0 To numLayer - 1
                pLayer = pMap.Layer(i)
                If pLayer.Name Like strPolygon5 Then
                        pCadLayer = pLayer
                        Next intLegendIndex
                    End If
                ElseIf pLayer.Name Like strPolygon1 Then
                        pCadLayer = pLayer
                        Next intLegendIndex
                    End If
                ElseIf pLayer.Name Like strPolygon3 Then
                        pCadLayer = pLayer
                        Next intLegendIndex
                    End If
                ElseIf pLayer.Name Like strPolygon4 Then
                        pCadLayer = pLayer
                        Next intLegendIndex
                    End If
                ElseIf pLayer.Name Like strPolygon6 Then
                End If
            pMXDoc.UpdateContents()
        Catch ex As Exception
            MsgBox(ex.ToString)
        End Try
    End Sub
