Hide IEditor.AbortOperation() message box
1250
01-31-2012 06:01 AM
StefanOffermann
I am developing an editor extension for ArcMap. The extension should forbid changes to features, which have a attribute value "deny" in a column to restrict any change to the feature. Therefore I check on every OnChangeFeature event if the feature has the attribute value "deny". If this is the case, the change has to be aborted. But when I call IEditor.AbortOperation(), a message box is displayed, for example "The feature(s) could not be moved. Failed to move related features [FeatureClass]" when moving a feature. Is there a way to get rid of that massage box or at least to customize the text?
#region IExtension Implementations
        public void Shutdown()
            _editor = null;
            _editEvents = null;
        public string Name
            get { return "ValidateFeatures_Extension"; }
        public void Startup(ref object initializationData)
            if (initializationData != null && initializationData is IEditor)
                _editor = (IEditor)initializationData;
                //Wire editor events.
                _editEvents = (IEditEvents_Event)_editor;
                _editEvents.OnStartEditing += EditEventsOnStartEditing;
        #endregion
        #region Editor event notification implementation
        private void EditEventsOnStartEditing()
            if (_editor.EditWorkspace.Type == esriWorkspaceType.esriFileSystemWorkspace)
                return;
            _editEvents.OnChangeFeature += EditEventsOnChangeFeature;
            _editEvents.OnCreateFeature += EditEventsOnCreateFeature;
        private void EditEventsOnChangeFeature(IObject obj)
            Validate(obj as IFeature);
        private void EditEventsOnCreateFeature(IObject obj)
        #endregion
        private void Validate(IFeature inFeature)
            var fieldIndex = inFeature.Fields.FindField("DENYCHANGES");
            if (fieldIndex < 0)
                return;
            if (inFeature.Value[fieldIndex].Equals("deny"))
                _editor.AbortOperation();
sapnas
if it is an exception then you could add try/catch block to bypass the message.
StefanOffermann
It is not an exception. The message box appears, after my code of the "OnChangeFeature" event handler "EditEventsOnChangeFeature" is fully executed. This is why I am not in the control flow anymore.
