Help with finding TextElement in PageLayout?
4070
11
06-09-2011 07:51 AM
AnnCrystal
Hi Guys:
This may sound simple to you. But I am stuck. I am trying to find whether there is a disclaimer text in the pagelayout. If not, I want to add one. Here is the code:
if (enumElement != null)
                    findElement = enumElement.Next();
                    while (findElement != null)
                        if (findElement is IParagraphTextElement)
                            findTextElement = findElement as ITextElement;
                            if (findTextElement.Text.EndsWith("></CLR>"))
                                MessageBox.Show("The Disclaimer Text, which autoupdates the time and date, is already placed in the map.");
                            else
                                graphicsContainer.AddElement(element, 0);
                                graphicsContainerSelect.UnselectAllElements();
                                activeView.PartialRefresh(esriViewDrawPhase.esriViewGraphics, null, null);
My else part is not working. Where am I wrong? How can I write that if there are no ParagraphtextElements, then add my text?
Thanks in advance for your help.
Ann
JoelFerreyra
Ann, Jeff, please could put code in Visual Basic Net, it happens that I can not do the equivalent = (.. I'm still very puppy programming on these issues.
Greetings!
MichaelRobb
Honored Contributor
Greetings!
You have to, of course, declair ArcMap.
 Public Sub PerformTest()
        Const myParaTextID As String = "MyDisclaimerTextID"
        Dim paraText As String = "Sample disclaimer paragraph text"
        Dim graphicsContainer As ESRI.ArcGIS.Carto.IGraphicsContainer = TryCast(ArcMap.Document.PageLayout, ESRI.ArcGIS.Carto.IGraphicsContainer)
        Dim element As ESRI.ArcGIS.Carto.IElement
        Dim elementProperties As ESRI.ArcGIS.Carto.IElementProperties
        ' Check if the disclaimer text element already exists in layout
        graphicsContainer.Reset()
        element = graphicsContainer.Next()
        While element IsNot Nothing
            If TypeOf element Is ESRI.ArcGIS.Carto.IParagraphTextElement Then
                elementProperties = TryCast(element, ESRI.ArcGIS.Carto.IElementProperties)
                If elementProperties.Name = myParaTextID Then
                    MessageBox.Show("The Disclaimer Text, which autoupdates " & "the time and date, is already placed in the map.")
                    Return
                End If
            End If
        End While
        ' No disclaimer found, so make one
        Dim paraTextElement As ESRI.ArcGIS.Carto.IParagraphTextElement = New ESRI.ArcGIS.Carto.ParagraphTextElementClass()
        Dim textElement As ESRI.ArcGIS.Carto.ITextElement = TryCast(paraTextElement, ESRI.ArcGIS.Carto.ITextElement)
        elementProperties = TryCast(paraTextElement, ESRI.ArcGIS.Carto.IElementProperties)
        element = TryCast(paraTextElement, ESRI.ArcGIS.Carto.IElement)
        ' Set this so it can be found if this method called again
        ' Set the actual text to display
        textElement.Text = paraText
        ' Set the size and location of the text box
        Dim envelope As ESRI.ArcGIS.Geometry.IEnvelope = New esri.ArcGIS.Geometry.EnvelopeClass()
        envelope.PutCoords(0, 0, 3, 1)
        element.Geometry = envelope
        ' Add the text box to the layout
        ArcMap.Document.ActiveView.PartialRefresh(ESRI.ArcGIS.Carto.esriViewDrawPhase.esriViewGraphics, Nothing, Nothing)
    End Sub
