Help with C# code
792
03-04-2013 06:38 AM
OscarCalderon
May be this is not a new post, but I did not find any solution for this, so... I have to layers one of points (cities) and another of lines (roads), I need to find the shortest distance between two selected cities, using the road layer. I have try using this code:
IFeatureLayer Temp_Line = (IFeatureLayer)Glb.Mapa.get_Layer(0);
            IFeatureLayer Temp_Point = (IFeatureLayer)Glb.Mapa.get_Layer(0);
            int x = Glb.Mapa.LayerCount;
            for (int i = 0; (i < x); i++)
                if (Glb.Mapa.get_Layer(i).Name == "Caminos" + "_Z" + Glb.Zona)
                    Temp_Line = (IFeatureLayer)Glb.Mapa.get_Layer(i);
                else if(Glb.Mapa.get_Layer(i).Name == "Fallas" + "_Z" + Glb.Zona)
                    Temp_Point = (IFeatureLayer)Glb.Mapa.get_Layer(i);
            IFeature pLine = Temp_Line.FeatureClass.GetFeature(1);
            IFeature pPoint = Temp_Point.FeatureClass.GetFeature(1);
            IProximityOperator pProximity = pPoint.Shape as IProximityOperator;
            double distance = pProximity.ReturnDistance(pLine.Shape);
            textBox1.Text = distance.ToString();
But is not working...
Thanks in advance...
