Create Stand Alone Feature Class
729
03-01-2013 03:55 PM
BrianBaldwin1
Hi All, I have a real beginner question here.
I am using this code from the Arc sample's, it is the CreateStandaloneFeatureClass.
Basically, what do I place in the OnClick Sub to call this function?  I have been doing a lot of reading and just ordered some books....but could use some help with this very basic concept.
Thus far, I had my Sub with this code: CreateStandaloneFeatureClass(, "Test", , "Test")
Public Function CreateStandaloneFeatureClass(ByVal workspace As IWorkspace, ByVal featureClassName As String, ByVal fieldsCollection As IFields, ByVal shapeFieldName As String) As IFeatureClass
        Dim featureWorkspace As IFeatureWorkspace = CType(workspace, IFeatureWorkspace)
        Dim fcDesc As IFeatureClassDescription = New FeatureClassDescriptionClass()
        Dim ocDesc As IObjectClassDescription = CType(fcDesc, IObjectClassDescription)
        ' Use IFieldChecker to create a validated fields collection.
        Dim fieldChecker As IFieldChecker = New FieldCheckerClass()
        Dim enumFieldError As IEnumFieldError = Nothing
        Dim validatedFields As IFields = Nothing
        fieldChecker.ValidateWorkspace = workspace
        fieldChecker.Validate(fieldsCollection, enumFieldError, validatedFields)
        ' The enumFieldError enumerator can be inspected at this point to determine
        ' which fields were modified during validation.
        Dim featureClass As IFeatureClass = featureWorkspace.CreateFeatureClass(featureClassName, validatedFields, ocDesc.InstanceCLSID, ocDesc.ClassExtensionCLSID, esriFeatureType.esriFTSimple, shapeFieldName, "")
        Return featureClass
    End Function
BrianBaldwin1
Just adding some clarification.  I have the function all built (from the sample code provided by ESRI), I just don't know how to call it with the OnClick Sub.
Thus far I have CreateStandaloneFeatureClass(, "Test", , "Test"), in the OnClick Sub, but I still need to provide the workspace and the fieldsCollection values, what would these be?
LeoDonahue
IWorkspace and IFields are two object references that you need to write code for, before you can pass them to that Sub.
I don't know, but it sounds like you are maybe creating a console application, in which nothing really exists until you create it?
These might help.
Creating Geodatabases
Create FeatureClass Snippet
