HELP - we need an expert please.... we lack experience to solve this problem
2283
11-04-2010 09:44 AM
JMJJDJM
Sorry but we do not know how to fix this:
I pass the code that applies symbolization a layer of points with
ClassBreaksRenderer and "Quantities" and mode "Graduated Colors" from a .NET aplication, but at the end of the process, No way to update the table of contents.
If we use ArcMap, right click, properties on the layer and look at the symbolization form, ALL is perfect and if you click the OK button, all is well.
We refresh contents with
pMxDoc.UpdateContents()
and the activeView with
pMxDoc.ActiveView.Refresh()
Someone could tell us where we fail?
Code A is failing
Dim pMxDoc As IMxDocument
Dim pLayer As ILayer
Dim pGeoLayer As IGeoFeatureLayer
Dim pFLayer As IFeatureLayer
Dim pFClass As IFeatureClass
Dim pRender As IClassBreaksRenderer
Dim pColor1 As IRgbColor
Dim pColor2 As IRgbColor
Dim pColor3 As IRgbColor
Dim i As Integer
'Dim pSFSym1 As ISimpleFillSymbol, pSFSym2 As ISimpleFillSymbol
Dim pSFSym1 As ISimpleMarkerSymbol, pSFSym2 As ISimpleMarkerSymbol
Dim pUIProperties As IClassBreaksUIProperties
Dim pRendererPropPage As IRendererPropertyPage
Dim pHistogram As IHistogram
Dim ptableHistogram As ITableHistogram
Dim pTable As ITable
Dim pClassify As IClassify
Dim classes() As Double
Dim dataValues() As Double, datafreq() As Integer
Dim pUIProp As IClassBreaksUIProperties
Dim fLR As IFeatureRenderer
Dim itemGal As IEnumStyleGalleryItem
Dim gallery As IStyleGallery
Dim gallery2 As IEnumStyleGalleryItem
Dim nom As String
Dim p1 As esriSimpleMarkerStyle
pMxDoc = m_pDoc
pLayer = pMxDoc.ActiveView.FocusMap.Layer(0)
pFLayer = pLayer
pFClass = pFLayer.FeatureClass
pTable = pFLayer
'ptableHistogram = New TableHistogram
'ptableHistogram.Field = "Valor"
'ptableHistogram.Table = pTable
'pHistogram = ptableHistogram
'pHistogram.GetHistogram(dataValues, datafreq)
'pClassify = New NaturalBreaks
'pClassify.SetHistogramData(dataValues, datafreq)
pRender = New ClassBreaksRenderer
pRender.Field = "Valor"
pRender.BreakCount = 2
pRender.MinimumBreak = 0
pRender.Break(0) = 249.9999
pRender.Break(1) = 5000
pUIProp = pRender
pUIProp.LowBreak(0) = 0
pUIProp.LowBreak(1) = 250
'pRender.Description(0) = "Cumple Legislación"
'pRender.Description(0) = "Incumple Legislación"
pRender.Label(0) = " < 250"
pRender.Label(1) = " >= 250"
pColor1 = New RgbColorClass
pColor1.RGB = System.Drawing.ColorTranslator.ToWin32(Color.Green Yellow)
pColor2 = New RgbColorClass
pColor2.RGB = System.Drawing.ColorTranslator.ToWin32(Color.Red)
pColor3 = New RgbColorClass
pColor3.RGB = System.Drawing.ColorTranslator.ToWin32(Color.Black )
Dim cc As IMarkerBackground
pSFSym1 = New SimpleMarkerSymbol
pSFSym1.Color = pColor1
pSFSym1.OutlineSize = 0.4
pSFSym1.OutlineColor = pColor3
pSFSym1.Size = 5
pSFSym1.Style = esriSimpleMarkerStyle.esriSMSSquare
pRender.Symbol(0) = pSFSym1
pSFSym2 = New SimpleMarkerSymbol
pSFSym2.Color = pColor2
pSFSym2.OutlineSize = 0.4
pSFSym2.OutlineColor = pColor3
pSFSym2.Size = 5
pSFSym2.Style = esriSimpleMarkerStyle.esriSMSCircle
pRender.Symbol(1) = pSFSym2
pRendererPropPage = New GraduatedColorPropertyPage
pGeoLayer = pFLayer
pGeoLayer.RendererPropertyPageClassID = pRendererPropPage.ClassID
pGeoLayer.Renderer = pRender
pGeoLayer.DisplayField = "Valor"
pGeoLayer.DisplayAnnotation = False
pMxDoc.ActiveView.PartialRefresh(esriViewDrawPhase .esriViewGeography, pLayer, Nothing)
pMxDoc.ActiveView.ContentsChanged()
Code B is running in VBA
    Dim pFLayer As IGeoFeatureLayer
    Dim pFclass As IFeatureClass
    Dim pFeature As IFeature
    Dim pFCursor As IFeatureCursor
    Set pMxDoc = Application.Document
    Set pFLayer = pMxDoc.ActiveView.FocusMap.Layer(0)
    Set pFclass = pFLayer.FeatureClass
    Set pFCursor = pFclass.Search(Nothing, False)
    Set pFeature = pFCursor.NextFeature
    Set pTable = pFclass
    Set pGeoLayer = pFLayer
    Set pRender = New ClassBreaksRenderer
    'Set pClassifyGEN = New Quantile
    Set pUIProperties = pRender
    pUIProperties.LowBreak(0) = 0
    pUIProperties.LowBreak(1) = 250
    pRender.Label(1) = " > 250"
    Set pColor1 = New RgbColor
    Set pColor2 = New RgbColor
    Set pColor3 = New RgbColor
    pColor1.Red = 0
    pColor1.Green = 255
    pColor1.Blue = 0
    pColor2.Red = 255
    pColor2.Green = 0
    pColor2.Blue = 0
    pColor3.Red = 0
    pColor3.Green = 0
    pColor3.Blue = 0
    Dim pSym1 As ISimpleMarkerSymbol
    Set pSym1 = New SimpleMarkerSymbol
    pSym1.Color = pColor1
    pSym1.Outline = True
    pSym1.OutlineSize = 0.4
    pSym1.OutlineColor = pColor3
    pSym1.Style = esriSMSCircle
    pSym1.size = 5
    pRender.Symbol(0) = pSym1
    Dim pSym2 As ISimpleMarkerSymbol
    Set pSym2 = New SimpleMarkerSymbol
    pSym2.Color = pColor2
    pSym2.Outline = True
    pSym2.OutlineSize = 0.4
    pSym2.OutlineColor = pColor3
    pSym2.Style = esriSMSCircle
    pSym2.size = 5
    pRender.Symbol(1) = pSym2
    ' assign renderer to layer
    Set pGeoLayer.Renderer = pRender
We use v9.2
Thanks in advance
Quim
AlexanderGray
Honored Contributor
Have you tried refreshing the TOC directly (contentsview)
something like this:
for i=0 to pMxDoc.contentsviewcount -1
  pMxDoc.Contentsview(i).refresh()
next
JMJJDJM
next
Thanks Alexander.
It does not work.
I think it's a matter of classbreaksRenderer renderer update, but not like you can do.
Maybe some configuration errors and the legend has not updated why not ...
mohamedkenzi
try to change the order of instructions :
define the style before defining proprieties outline, outlinesize and outlinecolor, ...
pSym2.size = 5
JMJJDJM
pSym2.size = 5
Thanks, but It did not work.
JMJJDJM
Code A is failing
Dim i As Integer
Dim nom As String
pMxDoc = m_pDoc
pFLayer = pLayer
pTable = pFLayer
pUIProp = pRender
pSFSym1.Size = 5
pSFSym2.Size = 5
pGeoLayer = pFLayer
    pColor1.Red = 0
    pColor1.Green = 255
    pColor1.Blue = 0
    pColor2.Red = 255
    pColor2.Green = 0
    pColor2.Blue = 0
    pColor3.Red = 0
    pColor3.Green = 0
    pColor3.Blue = 0
    pSym1.size = 5
    pSym2.size = 5
We use v9.2
Thanks in advance
Quim
Finally, we have seen, how to correct the ClassBreaksRenderer error.
The time lost is the worst.
The solution has been not to create a new symbol with 'NEW SimpleMarkerSymbol' :
  Dim pSimpleRend As ISimpleRenderer
        pMxDoc = m_pDoc
        pFLayer = pLayer
        pGeoLayer = pFLayer
        pSimpleRend = pGeoLayer.Renderer
        Good -> pSFSym1 = pSimpleRend.Symbol
        Bad -> pSFSym1= New SimpleMarkerSymbol
the rest of code is the same.
Thanks to those who have tried to help.
JMJ98
