Please Expret of ClassBreaksRenderer /ArcGis9.2/VB.NET/ - legendItems are NOTHING
1468
11-07-2010 12:19 AM
by Anonymous User
Not applicable
Original User: JMJ98
Hello
Hello
Please, we need an example of classBreaksRender, that worked well for VB.NET.
All we are trying to prove, not visualize the legend of the TOC. The link is an example of how the legend is running the following code (image 1 in attachment)
The second image represents the configuration of the renderer made by the code in VB. NET
The third image, so there is no way to get
(If we click the OK button in ArcMap (image 2), we get the image 3, but using the code is impossible)
Thanks for the help
Code for define ClassBreaksRenderer object:
        Dim pMxDoc As IMxDocument
        Dim pLayer As ILayer
        Dim pGeoLayer As IGeoFeatureLayer
        Dim pFLayer As IFeatureLayer
        Dim pFClass As IFeatureClass
        Dim pRender As IClassBreaksRenderer
        Dim pColor1 As IRgbColor
        Dim pColor2 As IRgbColor
        Dim pColor3 As IRgbColor
        Dim i As Integer
        Dim pSFSym1 As ISimpleMarkerSymbol, pSFSym2 As ISimpleMarkerSymbol
        Dim pRendererPropPage As IRendererPropertyPage
        Dim pTable As ITable
        Dim pUIProp As IClassBreaksUIProperties
        pMxDoc = m_pDoc
        pLayer = pMxDoc.ActiveView.FocusMap.Layer(0)
        pFLayer = pLayer
        pFClass = pFLayer.FeatureClass
        pTable = pFLayer
        pRender = New ClassBreaksRenderer
        pRender.Field = "Valor"
        pRender.BreakCount = 2
        pRender.MinimumBreak = 0
        pRender.Break(0) = 249.9999
        pRender.Break(1) = 5000
        pUIProp = pRender
        pUIProp.LowBreak(0) = 0
        pUIProp.LowBreak(1) = 250
        pRender.Label(0) = " < 250"
        pRender.Label(1) = " >= 250"
        pColor1 = New RgbColorClass
        pColor1.RGB = System.Drawing.ColorTranslator.ToWin32(Color.GreenYellow)
        pColor2 = New RgbColorClass
        pColor2.RGB = System.Drawing.ColorTranslator.ToWin32(Color.Red)
        pColor3 = New RgbColorClass
        pColor3.RGB = System.Drawing.ColorTranslator.ToWin32(Color.Black)
        pSFSym1 = New SimpleMarkerSymbol
        pSFSym1.Color = pColor1
        pSFSym1.Outline = True
        pSFSym1.OutlineSize = 0.4
        pSFSym1.OutlineColor = pColor3
        pSFSym1.Size = 5
        pSFSym1.Style = esriSimpleMarkerStyle.esriSMSCircle
        pRender.Symbol(0) = pSFSym1
        pSFSym2 = New SimpleMarkerSymbol
        pSFSym2.Color = pColor2
        pSFSym2.Outline = True
        pSFSym2.OutlineSize = 0.4
        pSFSym2.OutlineColor = pColor3
        pSFSym2.Size = 5
        pSFSym2.Style = esriSimpleMarkerStyle.esriSMSCircle
        pRender.Symbol(1) = pSFSym2
        pRendererPropPage = New GraduatedColorPropertyPage
        pGeoLayer = pFLayer
        pGeoLayer.RendererPropertyPageClassID = pRendererPropPage.ClassID
        pGeoLayer.Renderer = pRender
        '(Limite=50mg/l, RD 1514/2009
        pMxDoc.UpdateContents()
        pMxDoc.ActiveView.Refresh()
by Anonymous User
Not applicable
At last we have seen ClassBreaksRenderer correct the error.
How are you things we have wasted much time. ArcObjects is the worst thing that many behaviors are not understood the code.
The solution has been not to create a new symbol with SimpleMarkerSymbol but:
        pMxDoc = m_pDoc
        player = pMxDoc.ActiveView.FocusMap.Layer (0)
        pFLayer = Play
        pGeoLayer = pFLayer
        pSimpleRend = pGeoLayer.Renderer
        Good -> pSFSym1 = pSimpleRend.Symbol
        Bad -> pSFSym1 = New SimpleMarkerSymbol
Thanks to those who have tried to help
