Help on Putting Security when ArcMAP starts
1790
03-15-2011 12:32 AM
MuradJamal1
Hello
I am planning to implement a security layer to the ArcMAP application . the logic is that without a validated login no user cannot open the arcMap application.
Can anyone give any feedback on where to start or how to accomplish this
appreciate it
thanks
SteveFang
Not sure why you're doing it but one way you could implment this is through document events.  On document open go to a location for authentication (Windows, XML, or DB), return the results, if user is ok then you're done otherwise inform user and close down document.
MuradJamal1
thanks chump
i am trying to find an entry point to get the reference to the newly created document everytime you start the arcMAp application.
since i am not creating any custom extension or commands - i cannot use their oncreate .. etc events
if i create a custom arcmap Class from Visual Studio  what method or what should i use to get the reference
or is there any other way
thanks
SteveFang
I usually implement something like that in an extension.  But you are not going down that path.  What about embedding VBA code into your document to hook into the document event?  The downside is you now have to distribute that map document to all your users.
MuradJamal1
hello chump
i will try with the extension and see how it goes
thanks again
