Help in Irelationaloperation
786
04-19-2010 01:36 PM
SurenderGanta
I would like to know how can i select polygons around in a map which are touching a particular polygon. I have a polygon which is of interest for me (based on some population value). Now i want to select the polygons which are sharing the boundary with this polygon. I have tried using the irelationaloperator and ipolygon. But since I am a starter I am not able to come up with that. Any help would be appreciated.
JohnHauck
You can use the geoprocessing tool Select Layer by Location. You can access the Geoprocessor from VBA, .NET, Python, ect. The following has a .NET sample that shows the use of this tool, see the link for "Sample: Executing geoprocessing tools"
http://resources.esri.com/help/9.3/ArcGISEngine/dotnet/concepts_start.htm#7b2abf97-992f-4402-87e3-d4...
The geoprocessing tools honor selections so after you apply the selection for the geometry of interest you can simply use its layer and the additional layer as tool inputs.
