Help: Changing a point via form control makes existing point disappear
1014
12-20-2010 04:43 AM
JSan
New to ArcObjects - I have a point in an .mxd layer that I would like to change via user interaction on a form (button click).  However, when I run my application and click to update the point, the existing point in the target layer completely disappears.  Can anyone point me in the right direction?
                        IMxDocument _mxDoc = (IMxDocument)_doc;
                        IMap map = (IMap)_mxDoc.FocusMap;
                        IGeoFeatureLayer gLayer = (IGeoFeatureLayer)map.get_Layer(2);
                        IRgbColor pColor = new RgbColorClass();
                        pColor.Red = 255;
                        pColor.Green = 255;
                        pColor.Blue = 0;
                        ISimpleMarkerSymbol sMarker = new SimpleMarkerSymbol();
                        sMarker.Color = pColor;
                        sMarker.Style = esriSimpleMarkerStyle.esriSMSDiamond;
                        sMarker.Size = 20;
                        ISimpleRenderer sRender = (ISimpleRenderer)gLayer.Renderer;
                        sRender.Symbol = (ISymbol)sMarker;
                        gLayer.Renderer = (IFeatureRenderer)sRender;
                        IActiveView vActive = (IActiveView)map;
                        vActive.Refresh();
Venkata_RaoTammineni
                        pColor.Red = 255;
                        pColor.Green = 255;
                        pColor.Blue = 0;
                        sMarker.Size = 20;
                        vActive.Refresh();
what _doc is it Iapplication instance ? please can you send me complete code so that i understand the issue...
JSan
Below is the code I have been using.  I stripped out all of the other form controls.  I think I cast everything correctly and the problem was with the render.  Thanks for taking a look at this.
public partial class frmMain : Form
        public frmMain()
            InitializeComponent();
        //These hold the document and application references
        private IDocument _doc = null;
        private IApplication _app = null;
        //Point button code
        private void btnPointColor_Click(object sender, EventArgs e)
            IMxDocument _mxDoc = (IMxDocument)_doc;     //Cast as IMxDocument Interface
            IMap map = (IMap)_mxDoc.FocusMap;           //cast _mxDoc as Carto IMap interface
            IGeoFeatureLayer gLayer = (IGeoFeatureLayer)map.get_Layer(2);   //Cast map layer 3 as IGeoFeature layer
            //Set the new color for the point
            pColor.Red = 255;
            pColor.Green = 255;
            pColor.Blue = 0;
            //Point so we need a simple marker symbol
            sMarker.Size = 20;
            //Need to render
            ISimpleRenderer sRender = new SimpleRenderer();
            gLayer.Renderer = sRender;
            //_mxDoc.UpdateContents();
            vActive.Refresh();
        public frmMain()
        //Point button code
            pColor.Red = 255;
            pColor.Green = 255;
            pColor.Blue = 0;
            sMarker.Size = 20;
            //Need to render
            vActive.Refresh();
Hi Please follow below steps..
1) add basecommand class
using System;
using System.Drawing;
using System.Runtime.InteropServices;
using ESRI.ArcGIS.ADF.BaseClasses;
using ESRI.ArcGIS.ADF.CATIDs;
using ESRI.ArcGIS.Framework;
using ESRI.ArcGIS.ArcMapUI;
namespace PointRenderer
    /// <summary>
    /// Summary description for ShowPoint.
    /// </summary>
    [Guid("797af0fa-03d9-4e41-8c61-1109e3aff787")]
    [ClassInterface(ClassInterfaceType.None)]
    [ProgId("PointRenderer.ShowPoint")]
    public sealed class ShowPoint : BaseCommand
        #region COM Registration Function(s)
        [ComRegisterFunction()]
        [ComVisible(false)]
        static void RegisterFunction(Type registerType)
            // Required for ArcGIS Component Category Registrar support
            ArcGISCategoryRegistration(registerType);
            // TODO: Add any COM registration code here
        [ComUnregisterFunction()]
        [ComVisible(false)]
        static void UnregisterFunction(Type registerType)
            ArcGISCategoryUnregistration(registerType);
            // TODO: Add any COM unregistration code here
        #region ArcGIS Component Category Registrar generated code
        /// <summary>
        /// Required method for ArcGIS Component Category registration -
        /// Do not modify the contents of this method with the code editor.
        /// </summary>
        private static void ArcGISCategoryRegistration(Type registerType)
            string regKey = string.Format("HKEY_CLASSES_ROOT\\CLSID\\{{{0}}}", registerType.GUID);
            MxCommands.Register(regKey);
        /// <summary>
        /// Required method for ArcGIS Component Category unregistration -
        /// </summary>
        private static void ArcGISCategoryUnregistration(Type registerType)
            MxCommands.Unregister(regKey);
        #endregion
        #endregion
        private IApplication m_application;
        public ShowPoint()
            // TODO: Define values for the public properties
            base.m_category = "GIS_FORM"; //localizable text
            base.m_caption = "Render Point";  //localizable text
            base.m_message = "Render Point";  //localizable text
            base.m_toolTip = "Render Point";  //localizable text
            base.m_name = "Render Point";   //unique id, non-localizable (e.g. "MyCategory_ArcMapCommand")
            try
                // TODO: change bitmap name if necessary
                string bitmapResourceName = GetType().Name + ".bmp";
                base.m_bitmap = new Bitmap(GetType(), bitmapResourceName);
            catch (Exception ex)
                System.Diagnostics.Trace.WriteLine(ex.Message, "Invalid Bitmap");
        #region Overriden Class Methods
        /// <summary>
        /// Occurs when this command is created
        /// </summary>
        /// <param name="hook">Instance of the application</param>
        public override void OnCreate(object hook)
            if (hook == null)
                return;
            m_application = hook as IApplication;
            //Disable if it is not ArcMap
            if (hook is IMxApplication)
                base.m_enabled = true;
            else
                base.m_enabled = false;
            // TODO:  Add other initialization code
        /// <summary>
        /// Occurs when this command is clicked
        /// </summary>
        public override void OnClick()
            // TODO: Add ShowPoint.OnClick implementation
            PointRender _pointRender = new PointRender(m_application);
            _pointRender.ShowDialog();
        #endregion
2) Add Form
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Text;
using System.Windows.Forms;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Display;
    public partial class PointRender : Form
        private IApplication pApp = null;
        public PointRender(IApplication pApp)
            this.pApp = pApp;
        private void button1_Click(object sender, EventArgs e)
            try
                IMxDocument pMxDoc = pApp.Document as IMxDocument;
                IMap pMap = pMxDoc.FocusMap;
                IGeoFeatureLayer pGeoFeatLayer;
                pGeoFeatLayer = pMap.get_Layer(0) as IGeoFeatureLayer;
                IRgbColor pRGB = new RgbColorClass();
                pRGB.Red = 84;
                pRGB.Green = 156;
                pRGB.Blue = 227;
                ISimpleMarkerSymbol pSimpleMarkerSinboml = new SimpleMarkerSymbolClass();
                pSimpleMarkerSinboml.Color = pRGB;
                pSimpleMarkerSinboml.Style = esriSimpleMarkerStyle.esriSMSDiamond;
                pSimpleMarkerSinboml.Size = 10;
                ISimpleRenderer pSimpleRender = new SimpleRendererClass();
                pSimpleRender.Symbol = pSimpleMarkerSinboml as ISymbol;
                pGeoFeatLayer.Renderer = pSimpleRender as IFeatureRenderer;
                pMxDoc.UpdateContents();
                pMxDoc.ActiveView.Refresh();
            catch (Exception exp) { }
