Get IExtensionManager
2912
04-19-2010 02:23 PM
RiverTaig1
I'm trying to figure out how to get a refrence to IExtensionManager without using IApplication. This is an Engine application that I am developing, and IApplication isn't available (the typical sample has you casting from IApplication like so)
Dim pExtMgr As IExtensionManager
Dim pExt As IExtension
Set pExtMgr = Application
I tried to simply co-create the ExtensionManager like this:
IExtensionManager xMan = (IExtensionManager) new ESRI.ArcGIS.esriSystem.ExtensionManagerClass();
but it failed, "Unable to cast object of type 'System.__ComObject' to type 'ESRI.ArcGIS.esriSystem.ExtensionManagerClass'"
So how do you do this?
Thanks in advance.
AntJ
You can try with
IExtensionManagerAdmin pExAdmin = new ExtensionMangerClass();
IExtesnionManager pExtManager = (IExtensionManagerAdmin)pExAdmin;
nicogis
MVP Alum
ExtensionManagerClass is a singleton class see http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/interacting_with_single...
If you have this error is because you yet have a instance ExtensionManagerClass  that could be RCW generic System.__ComObject (in your case is so) so you cannot cast 'System.__ComObject'  to ExtensionManagerClass and ExtensionManagerClass  is a singleton.
you can resolve with
Type t = Type.GetTypeFromProgID("...");
System.Object obj = Activator.CreateInstance(t);
