Get a reference to a non-spatial data table on the source tab
2410
12-09-2011 12:51 PM
BrianWestfall
I need to query a table that has non spatial data and is available on the source tab.  If I physically select the table, the code below code works.  I don't want to be required to select the table in order to get the table reference and do the query.  Can someone tell me how to do this using the table name?
Thanks
Brian
Dim mxDocument As ESRI.ArcGIS.ArcMapUI.IMxDocument = CType(My.ArcMap.Application.Document, ESRI.ArcGIS.ArcMapUI.IMxDocument)
Dim contentsView As ESRI.ArcGIS.ArcMapUI.IContentsView = mxDocument.ContentsView(1) ' 0 = usually the Display tab, 1 = usually the Source tab
Dim table As ESRI.ArcGIS.Geodatabase.ITable = CType(contentsView.SelectedItem, ESRI.ArcGIS.Geodatabase.ITable)
Dim cursor As ICursor = PerformAttributeQuery(table, "OBJECTID = 1")
DuncanHornby
MVP Notable Contributor
You want to use the Interface IStandaloneTableCollection.
