Geoprocessing SDE Feature Classes
3550
7
12-04-2012 12:11 PM
LukeTaylor1
I'm trying to append two SDE feature classes together.  I've been able to piece together the following code with no luck.  My geoprocessor appears to be failing I believe because my feature classes are not wrapped in a strongly typed RCW, but I've not had any luck figuring out how to accomplish this (or I may be totally out in left field with what I'm trying to do).  Any thoughts would be greatly appreciated.
using System;
using System.Collections.Generic;
using System.Text;
using System.Windows.Forms;
using System.Runtime.InteropServices;
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.DataManagementTools;
using ESRI.ArcGIS.Geoprocessing;
using ESRI.ArcGIS.Geoprocessor;
using ESRI.ArcGIS.DataSourcesGDB;
using ESRI.ArcGIS.Geodatabase;
namespace T
    class Program
        private static LicenseInitializer m_AOLicenseInitializer = new T.LicenseInitializer();
        [STAThread()]
        static void Main(string[] args)
            //ESRI License Initializer generated code.
            m_AOLicenseInitializer.InitializeApplication(new esriLicenseProductCode[] { esriLicenseProductCode.esriLicenseProductCodeArcInfo },
            new esriLicenseExtensionCode[] { });
            //Do not make any call to ArcObjects after ShutDownApplication()
            // Get geoprocessor
            ESRI.ArcGIS.Geoprocessor.Geoprocessor gp = new ESRI.ArcGIS.Geoprocessor.Geoprocessor();
            gp.AddOutputsToMap = false;
            // Get append tool
            ESRI.ArcGIS.DataManagementTools.Append app = new ESRI.ArcGIS.DataManagementTools.Append();
            IPropertySet propertySet = new PropertySetClass();
            propertySet.SetProperty("SERVER", "xxxxx");
            propertySet.SetProperty("INSTANCE", "xxxxx");
            propertySet.SetProperty("DATABASE", "xxxxx");
            propertySet.SetProperty("USER", "xxxxx");
            propertySet.SetProperty("PASSWORD", "xxxxx");
            propertySet.SetProperty("VERSION", "xxxxx");
            // Use activator
            Type factoryType = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory");
            IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance(factoryType);
            //workspaceFactory.Open(propertySet, 0);
            //IWorkspaceFactory workspaceFactory = new SdeWorkspaceFactoryClass();
            IWorkspace workspace = (IWorkspace)workspaceFactory.Open(propertySet, 0);
            IFeatureWorkspace pFeatureWorkspace = (IFeatureWorkspace)workspace;
            //IFeatureWorkspace pFeatureWorkspace = workspaceFactory.Open(propertySet, 0) as IFeatureWorkspace;
            ESRI.ArcGIS.Geodatabase.IFeatureClass inputClass = (IFeatureClass)pFeatureWorkspace.OpenFeatureClass("sde.DBO.Tester2Updater");
            ESRI.ArcGIS.Geodatabase.IFeatureClass targetClass = (IFeatureClass)pFeatureWorkspace.OpenFeatureClass("sde.DBO.Tester2Updater");
            //MessageBox.Show(inputClass.ShapeType.ToString());
            IVariantArray array = new VarArrayClass();
            array.Add(inputClass);
            array.Add(targetClass);
            array.Add("NO_TEST");
            //IVariantArray array = new VarArrayClass();
            //array.Add(@"D:\ProjectData\TestData2\test2.shp");
            //array.Add(@"D:\ProjectData\TestData1\test1.shp");
            //array.Add("NO_TEST");
            gp.Execute("Append_management", array, null);
            m_AOLicenseInitializer.ShutdownApplication();
LukeTaylor1
Had a typo in code displayed, but not the problem...
ESRI.ArcGIS.Geodatabase.IFeatureClass targetClass = (IFeatureClass)pFeatureWorkspace.OpenFeatureClass("sde.DBO.Tester1Main");
MarcinDruzgala
Ok, first of all use CODE TAGS when you copy/paste your code;)
Next thing I don't see anywhere that you are using this Append process:
// Get append tool
and nothing more...
Here is the sample of using Append and Geoprocessor:
Append append = new Append();
append.inputs = inputClass;
append.target  = targetClass ;
append.schema_type = "NO_TEST"
GP.Execute(append , null);
and the documentation you should read: click!
Cheers
MDruzgala
LukeTaylor1
Thanks for the reply and the help with posting protocol.  I've tried this a thousand different ways, so sorry if I posted some obviously messy code.  I was trying to use an IVariantArray in this situation as I used it to append shapefiles that were on my desktop successfully.  However, I really believe the problem lies in the sde feature classes I'm utilizing not being .NET wrapped (just a generic System._ComObject).  I know my sde connection is fine as I've used it for other matters.
using System;
using System.Text;
using ESRI.ArcGIS.Carto;
namespace T
    class Program
        [STAThread()]
            // Get geoprocessor
            // Get append tool
            // Use activator
            //array.Add(inputClass);
            //array.Add(targetClass);
            app.inputs = inputClass;
            app.target = targetClass;
            app.schema_type = "NO_TEST";
            //This works for non-sde input (not worried about creating sde connection)
            //gp.Execute("Append_managament", array, null);
            //gp.Execute("Append_management", array, null);
            gp.Execute(app, null);
NeilClemmons
Honored Contributor
I would guess the problem is your program is ending before the geoprocessor has completed.  The call to Execute is asynchronous.  Your code will not stop at that point and wait for the process to finish.  Instead, it will continue on and in this case that's the end of the program.  You should be subscribing to the geoprocessor's events and waiting for it to finish before exiting your program.
LukeTaylor1
Thanks Neil for the suggestion.  I'll give it a shot.
MarcinDruzgala
Can you do something like this:
try
catch(Exception exc)
      MessageBox.Show(exc.ToString());
And if there is no error try this:
gp.ToolExecuted += new EventHandler<ToolExecutedEventArgs>(geoprocessor_ToolExecuted);
private void geoprocessor_ToolExecuted(object sender, ToolExecutedEventArgs e)
LukeTaylor1
Thanks for all the help guys.  Installing Service Pack 3 fixed the problem.
