Geoprocessing procedure SelectLayerByLocation COMException
1630
06-03-2011 01:44 PM
EliaszHaas
Hi!
I try to call geoprocessing procedure SelectLayerByLocation but I got COMException error (HRESULT E_FAIL).
I also tried some other geoprocessing procedures (Buffer) and it run well.
Here is code:
ESRI.ArcGIS.DataManagementTools.SelectLayerByLocation SelectInWorkLayerBuffer = new SelectLayerByLocation();
SelectInWorkLayerBuffer.in_layer = net_layer;
SelectInWorkLayerBuffer.overlap_type = "INTERSECT";
SelectInWorkLayerBuffer.select_features = work_layer_buffer;
SelectInWorkLayerBuffer.selection_type = "NEW_SELECTION";
gp.Execute(SelectInWorkLayerBuffer, null); //COMException
Any idea?
Piotr
KenBuja
MVP Esteemed Contributor
This code in VB.NET works for me.
Dim pFlayer As ESRI.ArcGIS.Carto.IFeatureLayer
Dim pFlayer1 As ESRI.ArcGIS.Carto.IFeatureLayer
pFlayer = pMxDoc.FocusMap.Layer(1)
pFlayer1 = pMxDoc.FocusMap.Layer(0)
SelectbyLocation(pFlayer, pFlayer1, "INTERSECT", "NEW_SELECTION")
    Friend Sub SelectbyLocation(ByVal InputLayer As ESRI.ArcGIS.Carto.IFeatureLayer2, ByVal SelectionLayer As ESRI.ArcGIS.Carto.IFeatureLayer2, ByVal OverlapType As String, ByVal SelectionType As String)
        Dim SelByLoc As New ESRI.ArcGIS.DataManagementTools.SelectLayerByLocation
        Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2
        Try
            Using releaser As New ESRI.ArcGIS.ADF.ComReleaser
                releaser.ManageLifetime(SelByLoc)
                SelByLoc.in_layer = InputLayer
                SelByLoc.overlap_type = OverlapType
                SelByLoc.select_features = SelectionLayer
                SelByLoc.selection_type = SelectionType
                Result = RunTool(SelByLoc, Nothing)
                If Result Is Nothing Then
                    System.Windows.Forms.MessageBox.Show("Could not select features")
                End If
            End Using
        Catch ex As Exception
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Select Layer by Location")
        End Try
    End Sub
    Private Sub ReturnMessages(ByVal pResult As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Title As String)
        Dim ErrorMessage As String
        If pResult.MessageCount > 0 Then
            For Count As Integer = 0 To pResult.MessageCount - 1
                ErrorMessage += pResult.GetMessage(Count)
        End If
        System.Windows.Forms.MessageBox.Show(ErrorMessage, Title)
    End Sub
    Friend Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel2) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2
        Dim GP As New ESRI.ArcGIS.Geoprocessor.Geoprocessor
        Try
            Result = CType(GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2)
            If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then ReturnMessages(Result, "Geoprocessing Error")
            GP.ClearMessages()
            ReturnMessages(Result, "Fail")
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Run Geoprocessor")
        End Try
        Return Result
    End Function
EliaszHaas
Thanks!
Your code was helpful to find the reason why my code failed (ReturnMessages)
Piotr
KenBuja
You should also note that in ArcGIS 10, the Geoprocessing tools run in code will also show up in the Results window. You can check there for problems with your code. The attached picture shows the results of testing the code in my previous post.
